Question about RIM BlackBerry 8800
Blackberry 8800 will not charge on wall charger
My Blackberry 8800 will no longer charge. I think it has something to do with the port because it started yesterday and when I wiggled it, it began charging, but now, nothing....
  • 407 Answers
You need to find out if the problem is with your current AV charger - the battery or the phone.
Clean the battery and the metal connection with a dry cloth, and try to charge using a USB charger.
Posted on Jun 03, 2009
I took this blackberry bold out of a recycle bin at my school and when i plug it into my dads bb charger the red light comes on but after 10 minutes of charging it still wont turn on.I think its a corrupt...
try this:
JUMP STARTING A BLACKBERRY
1. Plug wall charger into wall and then plug into blackberry
2. Take off back cover and pull the battery out (while it is plugged in still)
3. Wait 30 seconds. The red LED may remain on (tech said it didn't matter).
4. Put the battery back in and wait about 5-10 seconds and it'll begin to boot up (white screen with clock icon).
Jan 28, 2011 | Computers & Internet
My blackberry 8800 will not charge even when i put in a new battery !!
First Option:Please change The Phone Bettery and charger and check The check The Phone charging
IF Charging Problem will Not Solved So
Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
thanks.
Jun 21, 2010 | RIM BlackBerry 7250
8310 no longer takes a charge. Now completely dead. Have tried 3 proven good chargers.
Check with the device USB pin ..
Check with new Battery .
If everything is done there might be hardware problem, Contact service center
Oct 31, 2009 | RIM BlackBerry 8800
Why will my phone not power on? The let stays solid while charging but will not power on
are you trying to charge the phone with the wall charger or the USB cable. if it is the USB cable then chk if the USB port both on the laptop and the hand held is faulty or not, then chk if the USB cable is faulty or not. if you are to charge through the wall charger then check if the charge is faulty if every thing this is fine then get chk the battery.
Aug 07, 2009 | RIM BlackBerry 8800
My BlackBerry won't charge, and I think it is related to the phone and not the charger. Any troubleshooting tips?
Its the problem with the battery. Soo try getting a new one. Its not the charger,
Good Luck!!
Aug 06, 2009 | RIM BlackBerry 8800
Not charging
Go to your cell phone store and have them try another charger.
If that doesn't work your phone is damaged and needs to be repaired.
I hope this helps.
Jul 17, 2009 | RIM BlackBerry 8800
Blackberry world edition, will not charge...
What you can do is use the usb cable that came with your phone and hook it up to the computer to charge this will work unless there is something wrong with the phone itself the second option you could do is buy yourself a travel charger you can plug into the wall :).
Jun 22, 2009 | RIM BlackBerry Bold Smartphone
My Blackberry Wont charge?!
look at the 6 pins on the phones charge port and see if one is higher than the others (usually on the end). if the pins is too far up the lower half doesnt connect to the charger. If your usb port will charge on via usb "DOCK" then more than likely the charger itself (which is way more simple to fix)
1.) if one of the pins on the phones charge port is pushed up, grab a sewing needle and GENTLY push the pin back into place,
2.) if the charging dock is working and is a usb charger like your wall charger, buy a new wall charger at your local electronics store.
hope this helps!
Jun 12, 2009 | RIM BlackBerry Pearl 8100
My Blackberry pearl will not charge via wall outlet charger or USB (or any other charger). The battery is fine as I can charge it in my other blackberry and I have to keep switching batteries back and...
Your most likely going to have to buy a new phone my blackberry pearl did the same thing and it was because something was wrong with the inside of the charger port mine would say it was charging for all of about 5 seconds then disappear or you can go to your phone company and tell them that it is messed up and ask them for more batteries. good luck hope i helped :)
Mar 12, 2009 | RIM BlackBerry Pearl 8100
Blackberry 8800 buttons
Try pulling the battery out again, but this time when the device is on.
Mar 27, 2008 | RIM BlackBerry 8800
RIM BlackBerry 8800 Logo
923 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
