Question about Saws
Hand jig saw stops cutting - makes whirring noise - then restarts
I am cutting 3/16 perforated aluminum sheets, free hand lines. I have two older jig saws. Both worked fine for their first 10 feet, now both make this whirring noise and will not proceed until the whirring stops when I back off on the cutting - then they (each) will work for another 1/4'' of cutting.
    President:
  • 1,902 Answers
Jig saws are not made to cut through aluiminum espescially that size. That is really thick and it sounds like you have worn out the motor trying to cut it. If the saws are hot. Let them cool down then proceed but like I metioned before you are putting a lot of stress on something not made to cut aluminum even with a metal cutting blade
Posted on May 21, 2009
Tension onmy jig saw is tightened to the max, but it still won't cut a straight line.
I do not know which jig saw you have, but here are two generic answers.
1) Be sure the guide wheel that is behind the blade is nearly touching the rear of the blade.
If it is loose, the blade is more free to turn one way or another whilst cutting.
That wheel is round and has a groove or slot in it for the back of the blade to ride in.
2) Be sure the blade is sharp and has the right amount of teeth for the job.
A dull blade, or one made for another kind of material can give you trouble.
God bless your efforts.
Oct 25, 2016 | Saws
Is this table saw safe for sheet metal cutting
No. A table saw IS NOT safe for sheet metal cutting. I have seen bar stock aluminum and copper cut on a table saw (at least 1/4 inch thick) but trying to cut thin sheet metal would be a bad idea. The two main problems are that the sheet metal is too flexible and the teeth are much larger than the material is thick.
Dec 19, 2012 | Craftsman Sears Table Saw Manual Model...
Setting up a jig saw to cut a straight 1/4 inch
You will need two C clamps and a straight edge,I use a metal yard stick.Whatever you use look down the edge a make sure it's true.
Set up on the line and make sure the blade is going to cut on the waste side of the line.Measure the distance from the edge of the wood to the other side of the jigsaw glide plate and make a mark.Transfer the measurement to the other end.I move the blade up just above the surface so I can set the jig saw on the wood while I get the measurements.The last step is to clamp the straight edge down.Make sure to have the clamps with the handles down.Check under to make sure you won't run into any thing and do a dry run to check for cord hang ups.This is the best way as long as you keep the edge of the bottom jig saw plate against the straight edge.^^^^ Well that's how I do it. good luck
You can all so use the T bar attachment that slides through the bottom plate and clamps down with thumb screws.Personally I like the straight edge.
May 10, 2011 | Skil 94500 Jig Saw Rip Fence
Can a jig saw rip fence (Skil rip fence model No. 94500), with adjustment on the shaft from zero to five inches, be used to make a circular cut with a 8 inch radius (i.e., a 16 inch diameter cutout)?
no, will never happen. Make yourself a jig, 1/4" plywood set on your table top woth a small brad set 4" from blade. make a tiny hole in board to be cut into circle, spin the board on the brad, and look a wagon wheel.
Mar 11, 2011 | Skil 94500 Jig Saw Rip Fence
When I try to cut with my saw, the blade bends so that the cut is at an angle. Because of this angle cut, it is difficult to follow a line but even if I can follow the line, the angle cut through a 3/4...
This is a common issue with jig saws. There are sometimes larger blades, but all seem to distort to some degree. The only real solution is to go slow enough to allow the blade to return to it's normal shape...Essentially, is sounds like another tool would work better, but often you are scrolling with a jig saw and circular saw (for example) would not work.
The other workaround involves several cuts, so the final cut is removing much less material.
Nov 07, 2010 | Black & Decker Black decker Firestorm...
How to cut a 45 degree angle on wood using a jig saw
use a combination sliding square to mark ecxactly where you want to cut. Measure the distance from the jig-saw blade to the edge of the jig-saw bottom plate. Use this distance to mark another line parralel to the first line. Nail or screew a straight piece of wood on the second line. Put the jig-saw plate against the wood fence and cut your perfect line.
Mar 17, 2010 | Franke EuroPro Series GN1845SP Solid Wood...
My jig saw doesn't cut a straight line
Jigsaws aren't known for their straight cut performance. Use a radial saw.
Jan 08, 2010 | Ryobi Saws
Blade won't stay straight
Use a higher quality blade, this will help.
It happens with a Jig saw. You have to mind the direction of the force you push on the unit.
A better blade will cut easier and faster and will be less likely to bend.
ALSO: this tool has orbital. This feature makes the unit cut much faster but is much less accurate for cutting. If you need to make a really straight cut, make sure orbital is off.
Nov 20, 2009 | Milwaukee Tool Milwaukee 6266 - 22 6.2 -...
Grinding noise when printing and cuts paper
There may be something stuck in the area of the perforation, like a paper clip, paper debris or some foreign material. I would look in that area with a flashlight and see if there is something in the Paper feed roller area.Something may have come loose if you had a paper jam. Let me know.
Please remember to rate all users who assist you for free :)
Sep 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Saws Logo
123 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
