Question about Haier RWT350AW Washer
Belt slipping in wash mode aggitator does not aggitate belt is slipping can it be tightened
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
I cant lift trhe bottom aggitate plate in my hmwm8000 i have removed the cap and phillips head screw how tov lift the plate?
there should be a bolt holding aggitator on spines,if not try grabbing aggitator and pulling up while rocking aggitator back and forth it will require a great amount of force to remove aggitator fron splined shaft,also so penatrating spray may help sprayed on splined shaft.It also may need to be cleaned around splined shaft to clean built up soap build up. also a haet gun or a hair dryer on high heat on top of aggitator shaft when trying to remove may help!
Jun 12, 2011 | Washing Machines
Washer aggitates poorly when it is loaded
Check belt tension. Motor capacitors weak. Check the spin mode. Finally check the motor.
Apr 03, 2010 | Washing Machines
My washer won't spin or aggitate. I have a GE
Check the belt and clutch in the front under the lid run a butter knife under the lid and pop the front off and take a look.Have a great Thanksgiving.
Nov 25, 2009 | General Electric WHDSR209DWW Top Load...
Aggitator does not work, makes sounds
if the spin cycle works it's probably a broken belt, otherwise you need a new motor
Aug 14, 2009 | Kenmore Washing Machines
My aggitator wont stay down to wash clothes we have to hold it to work
There is a 1/4 inch hex head bolt on the side of the agitatot that has loosened. Tighten it.It is just above the lower agitator vanes.
Apr 12, 2009 | Washing Machines
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
Aggitator is lose small items (socks) fall down behind aggitator
When the wash plate is loose (can be lifted up and down) it means that your washer needs a u-joint kit. Yes, Whirlpool actually came out with an entire kit for this.
Tightening the bolts (actually there are 6 of them) won't fix your problem. The kit number is 285927. There's an instruction sheet included with it.
After you get the kit and are ready to install it, remove the white plastic dome by inserting a flat screwdriver into the 4 small slots (look closely and you'll see them) and lifting up at the same time.
*Beware... this is a MAJOR job. Be prepared to spend a long time on it. You'll need to lift the top panel, remove the balance ring, remove the wash plate, remove the drive block nut (<---sometimes requires a torch), etc... It may not be something you wanna jump into. Call an appliance repair outfit and ask them what they'd charge to install one if you ordered the part.
Mar 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Haier RWT350AW Washer Logo
94 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
