Question about Euro-Pro 7500XH Mechanical Sewing Machine
Motor grinds but nothing moves
My machine wont run. It makes a motor noise but nothing moves
    Problem Solver:
  • 9 Answers
Your bobbin winder is engaged check it and make sure it is off
Posted on May 23, 2009
I went to use my Necchi Lydia machine and the motor is making a terrible noise and the machine will not sew. Does it need cleaning, oiling or do I have a motor issue?
I have a Necchi Logica (Kenmore Sensorsew) and it was making a grinding noise, I bought new brushes, bought a technical repair manual for my machine. But, it needed a new motor, so if it is making a grinding noise, it is because the motor seized up and broke the pulley for the belt. No one would fix it because it was too old, I bought it new in 1988. Well, I kept watching on ebay and found a used motor, that was the answer. If, that is your case and you really love your machine be patient and find a motor, but just be sure that you don't spend more than it is worth. Sometimes, those "old girls" can be had for a reasonable price for the whole machine. I see on ebay, a few for sale at around $100 but shipping is $50 some dollars. They are heavy, and they were made in Italy, so kind of nostalgia.
Dec 31, 2017 | Necchi Sewing Machines
Pfaff 1222 E Makes a whirring noise, wheel won't turn
How long has it been since it's had a thorough cleaning & oiling (including the internal moving parts)? Resist trying to run the machine if the only thing running is the motor. You could burn up the motor or possibly break a gear.
The following method has helped me rescue some frozen older Berninas (which your model seems to resemble). This method worked on all of them except one that also needed a cracked gear replaced.
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Oct 31, 2016 | PfaFF Sewing Machines
Just turned machine on after being off and unpugged for a month or so and it is making a noise like a motor is running. any suggestions?
Question on sewing machine motors on vintage machines. - Sewing ...
artisanssquare.com > ... > Sewing Machines
Apr 28, 2010 - 20 posts - ‎4 authors
I've recently acquired 3 vintage machines a Singer 201 and 185 and a New ... When the motor is making some noise, but nothing is moving yet, that .... look - fragile, warped ? something like that anyway - in the first few turns.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Nov 7, 2014 - Well, I've been teaching on Janome machines for about 6 years, and I ... Take the Trouble Out of Sewing Machine Troubleshooting! .... Problem #7: Themachine is trying to sew and making sewing-like sounds, but ..... My Brother sewing machine JX2517 just shut down while I was ... in or close to the motor.
Six Common Sewing Machine Problems Solved ' eBay
www.ebay.com > ... > Sewing Manuals & Instruction
Sewing machines sometimes seem to have a life of their own when it comes to working ... sewing problems can be fixed or prevented just by making sure themachine is... ... If the sewing machine is making uncommon noises, such as grinding or ... Do not use the machine when it is operating this way, and turn off power to ...
Let's Talk Sewing Machine Maintenance! ' LLADYBIRD
lladybird.com/2013/02/13/lets-talk-sewing-machine-maintenanc/
Feb 13, 2013 - At the risk of sounding like a big fat sewing machine snob, it makes me cringe ... I understand that it may not be common knowledge that sewing machinesneed regular ... If the idea of poking around in your machine just sounds too ...... now the tune up turn into oiling the most basic part of your machine, .
Jan 25, 2016 | Sewing Machines
Singer curvy 8770 needle wont move
possibly has a broken belt a repair shop might be your best bet
Sep 27, 2017 | Singer Curvy 8770 Electronic Sewing...
Brother sewing machine noise
Sound like the whole unit needs a good cleaning.
My rule is "if it moves give it a lube", be careful not to get oil on electric boards or in the motor. What is the make and model of your machine. I will try to help you more.
Feb 26, 2013 | Sewing Machines
Makes a grinding noise when I turn it on, otherwise, it works fine.
The lubrication on the moving parts is poor and so there is friction on the bushes and linkages. If you can use some light oil on all the lubircating holes and also on the moving hinges the noise will diappear and also the machine will start with up with ease .
Apply oil and run, then reapply once till the motion becomes free.
Aug 01, 2011 | Sewing Machines
THE belt that runs top to bottom does not move,do i need a new belt?whats the #?
If the belt is in good shape it may be either a seized drive train or a bad motor. Remove the belt and check to see if the motor runs when the treadle is depressed. Try turning the machine by hand and feel for resistance and listen for grinding, squealing or rubbing noises.
May 13, 2011 | Necchi Sewing Machines
I have a Singer 7462 and when I try to load a bobin, the machine makes a nasty grinding noise and the needle slowly moves up and down and ultimately all of the lights on the stitch selection panel flash...
Ok, this is pretty common. Disengage the machine (as if you were winding a bobbin) run the machine at high speed for 5 minutes.
The motor is dirty and this will clean it out. You should hear the pitch of the motor change as the minutes go by.
Aug 24, 2010 | Singer 7462 Mechanical Sewing Machine
Euro-Pro 7500XH Mechanical Sewing Machine Logo
227 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
