Question about Apple iPad Tablets & eReaders
Cannot pair my ipad to greatshield ultrathin keyboard
Cannot pair it to greatshield keyboard
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
Feb 08, 2015 | Logitech Ultrathin Keyboard Cover
Using the keyboard for iPad not typing on the screen
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On.
Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-0.jpg using-keyboard-ipad-not-typing-screen-jq4dbyibaqf10wv4m2e43laj-1-2.jpg
Sep 15, 2014 | Apple iPad Tablets & eReaders
My shark keyboard for iPad air does not pair for blue tooth operation
Perhaps you look on this link to see you did everything right, like charging the battery, switching on and pairing. Don't forget to switch on bluetooth on your iPad. SHARKK Apple iPad Air Wireless Bluetooth Keyboard Case
Sep 10, 2014 | Apple iPad Tablets & eReaders
Can not get keyboard to pair with ipad
Make sure the keyboard has been fully charged. Most BT keyboards do have provisions to get power from the iPad.
Jul 18, 2014 | ZAGGkeys Cover and Bluetooth Keyboard for...
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Bluetooth keyboard will not connect
I'm assuming Bluetooth is turned on on the ipad.
follow the keyboard instructions to put it in pairing mode.
Then in ipad settings - Bluetooth you may need to select the keyboard.
Feb 26, 2014 | Apple iPad Mini
Tablets & eReaders Logo
79 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
