Question about Hayward 1.5 Hp Northstar High Performance Pump
Pool pump motor will not turn or take power - Hayward 1.5 Hp Northstar High Performance Pump
  • 366 Answers
You either have a bad start capacitor, bad bearings, or bad wiring. make sure all the wiring is tight, make sure the motor spins freely, and check the capacitor for leakage or "bloating".
In rare occasions, the motor windings can develop a direct short and cause the breaker to immediately trip.
Posted on Sep 16, 2009
Pool pump has power but wont turn on
with pump off try turning the motor shaft a few times then try if doesnt start need a new motor
Sep 06, 2013 | Pentair Whisperflo 075 Hp Ur Pool Pump...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Pump has power at back of motor and I can turn shaft at the back of pump. It is not running.
this motor has a run capacitor, have it tested. search your area for your local pool pump motor repair guy with free testing.. ask him how to remove it, caps can hold a charge and make for a nasty surprise.. THIS IS IF THE MOTOR HUMS OR MAKES A BUZZ NOISE if not, you will need to check the power at THE BACK OF THE MOTOR. no power check, timer, breaker, main breaker ..
Jun 06, 2011 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
My pump pool starts to pump for a few seconds and then the pump turns off. what you think is the problem?
short in motor check power going to motor make sure it in the rite setting 110v or 230v check for lose wires
Feb 12, 2011 | Hayward 2 Hp Tristar Inground Swimming...
I have a A O Smith SN 1152 pool pump. The motor just hums when the switch is turned on. The pump is eight years old and I have had no problems until now.
Remove the 4 fasteners that hold the pump head onto the motor and try to turn the motor shaft by hand. If it turns freely, apply power and see what happens. If it turns Ok, then your problem is the pump head not the motor. If the motor does not turn by hand then it needs to be replaced. If it turns by hand but not when power is applied, you may get away with replacing the bearing in it.
Nov 18, 2010 | A.O. Smith SQ1102 Pool Pump Motor
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
I have an A.O.Smith Century Pool & Spa motor 1081 pool pump duty 1.5 HP. It is making a very loud noise, do you think it needs replacement or should I look for something else?
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Jun 19, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
Hayward 1.5 Hp Northstar High Performance Pump Logo
165 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
