Question about Royal Alpha 1000ML Cash Register
Clear the running total royal 1000ml - Royal Alpha 1000ML Cash Register
2 Suggested Answers
Electroboy
  • 1770 Answers
SOURCE: royal cash register Alpha 1000ml electronic journal cleared
Royal don't tend to give out this info. and this model is rare to find. You will need the code for Journal clearing. I've found that it varies too much between registers to guess it by other ones. For the royal machines, I usually just send customers to buy the manual from the supplier. There is also a PDF manual on the net if you need one quickly:
https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Sorry I can't help further with this model
Posted on May 09, 2015
How do you delete gt from a royal 1000ml
I haven't worked on the 1000ml. There should be a code in your manual in the system settings. I usually just send my Royal customers to checkout tech since they have most of the Royal stuff https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Hope that helps
Jan 19, 2018 | Retail Supplies
How to delete the GT
I haven't worked with the 1000ml but you usually have to enter special codes or reset the machine to clear the GT as it is the last line of defence against fraud. There seems to be a manual on line that should have what you need:
May 20, 2016 | Royal Alpha 1000ML Cash Register
How clear memory royal 1000ml cashier
In order to clear the memory of a Royal 1000ml cash register, you would do the following:
1. First turn off the cash register without unplugging it and slide the control switch to the "off" position.
2. Open and remove the printer cover and put it to the side. Take out the paper roll and put it to the side as well. Open and remove the battery compartment cover and set it to the side.
3. Notice where the batteries are in the slots and note the orientation of the batteries, such as the positive and negative marks and then pull out the batteries.
4. Now unplug the cash register and wait at least 20 minutes to plug it in again. Slide the control switch to either the R1 or R2 position.
5. Put the batteries back as they were before and put back the battery cover, along with the paper roll and printer cover.
6. Select a mode using the control switch and then reprogram the register as needed with your settings.
May 23, 2015 | Retail Supplies
Royal cash register Alpha 1000ml electronic journal cleared
May 09, 2015 | Royal Alpha 1000ML Cash Register
What does sec,next code mean
The 1000ML is quite rare. Royal don't give out this info. I ended up sending my last few customers to this site:
Hope it helps.
Apr 28, 2015 | Royal Alpha 1000ML Cash Register
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2ΒΌ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Royal 1000ml user manual
This one is the full operation and programming manual.
It can help you to program date, time, receipt, tax, departments, reports and more
http://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
May 04, 2012 | Royal 1000ML 29403X Heavy Duty Register...
Royal Alpha 1000ML Cash Register Logo
52 people viewed this question
Top Royal Retail Supplies Experts
Patrick Tinashe...
Electroboy
Electroboy
Kevin.
Are you a Royal Retail Supply Expert? Answer questions, earn points and help others
