Question about iSimple Solutions Peripheral Isimple Isbt21 Pxamg/upac Bluetooth Adapter
BluStream ISBT52 pairing
Toyota 4Runner trying pair but won't discover device
Getting a PDL FULL message when trying to pair a device
I'm having the same issue right now.. How did you fix it ?
Dec 06, 2013 | iSimple Solutions Car Audio & Video
Plaintronics m25 will not pair!
Could be defective...
Try to entirely power off and then power on and try again
Nov 03, 2017 | Plantronics M25 Bluetooth Headset
When i pair my motorola S9 it won't pair is there any chance to reset the passcode?
Hey Michael. Are the s9s already paired with another device? If so.... You might want to try turning off both the s9 and the device that's already paired. Then try repairing new device with s9s. Good luck.
Sep 22, 2012 | Motorola Mobility S9 Headphones
Discover Bluetooth Device Not Available
uninstalled the rom
bad idea that.! why mess with ROM. ouch.
test the PC on other BT devices, if it works then the PC is good.
even a BT head set, mouse, or any other vast numbers of BT devices, (not apple sure)
Mar 08, 2017 | HP Pavillion DV6227 Notebook
I need to install bluetooth modem for my laptop HP compaq mini110c-1111ev pc
I am glad to HELP YOU!
All you have to do is to PAIR the both devices. So TURN ON the bluetooth on your HP mini and turn ON the Bluetooth Modem.
Right-click on the Bluetooth icon on your laptop and choose ADD DEVICE and let it discover the modem.
Once discovered add it as a paired device and [... probably] you ill have to input the PAIRING CODE for your modem.
Once paired click OK and you're good to go!
GOOD LUCK!
________________
Windows 7 tips
Apr 24, 2011 | Computers & Internet
How do i pair this bluetooth
you must put the device into pairing or discovery mode then search or add new device from your phone menu once they have discovered or paired you will need a 4 digit pin or pairing code ,Most blue tooth device manufactures use the following codes 0000,1234,1111,or 9999 i hope this helps
Feb 20, 2011 | LG HBM-310 Bluetooth Headset
How do I put it in discover mode?
How to Pair Cardo S-800
1.Turn on your phone and turn ON its Bluetooth function.
2.Make sure the headset is turned OFF, then press and hold the Power Button for approximately 8 seconds until the LED status indicator begins alternating blue and red, indicating that the headset is in Pairing Mode.
3.Set the phone to search for Bluetooth devices by following the instructions in the phone’s user guide. This is usually found in the phone’s Bluetooth menu and may be referred to as “discover” or “add” a device. (Settings > Connectivity > Bluetooth - turn ON - > Discover Devices)
4.After a few seconds, the phone will list the “Cardo S-800” as a discovered device. Select it from the list and press “oK” or “yes”.
5.When prompted, enter the passkey “0000” (4 zeros) and press “oK” to complete the pairing
6. When the pairing pairing is successful the headset’s LED status indicator will begin flashing.
You should now be able to make and receive calls using your headset. To initially connect the headset to your phone, you may need to tap the CTRL Button once on the headset. iMPortAnt: if pairing is not completed within 2 minutes while the Pairing Mode is activated, the headset will return to Standby mode, flashing blue once every three seconds and you must start the Pairing process again from Step 2 above.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 07, 2010 | Cardo S-800 Bluetooth Headset Wireless...
Cant pair my wep 500 with my phone
passcode = 0000 (4 zeros) USER GUIDE
The first time you turn on the headset it will enter "Pairing" mode. In this mode you can connect your headset with your phone or other Bluetooth enabled device. If you have already connected one device to the headset, you can enter Pairing mode by holding the multi-function button turns solid blue.
Once in pairing mode, set your phone or other Bluetooth enabled device to search for the headset. While each device is different, the setting is often found in a "Settings" or "Bluetooth" menu and the "Search" or "Discover" Bluetooth devices option. On the list of discovered devices, choose "Samsung WEP500" and select "Yes" or "Ok" to connect to the device. When asked for the passkey, enter 0000.
Feb 05, 2010 | Samsung WEP500 Wireless Headset
Our SGH-c417 Samsung cell phone will pair easily with a bluetooth headset but with our Toyota built-in bluetooth handsfree headset, it will not pair. It just searches and searches and never finds the...
I have had a similar issue with SGH-A707, I have found that taking the device out of discover mode, then removing the battery from the phone to reboot it. once booted, turn on the bluetooth on the phone and put the device into discover mode. Should find it.
Mar 20, 2009 | Samsung C417 Cellular Phone
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to www.n1wireless.com
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
iSimple Solutions Peripheral Isimple Isbt21 Pxamg/upac Bluetooth Adapter Logo
83 people viewed this question
Top iSimple Solutions Car Audio & Video Experts
xxxxxx xxx
Are you an iSimple Solutions Car Audio and Video Expert? Answer questions, earn points and help others
