Question about Toshiba Satellite L35-S2366 Notebook
BLUE SCREEN; AutoFocus " UNMOUTABLE_BOOT_VOLUME "
Hey i tried turning my computer on and this blue scree came on saying this " a problem has been detected and windows has been shut down to prevent damage to your computer... UNMOUNTABLE_BOOT_VOLUME " then i tried reseting it by pressing F8, and the same blue screen came on. i have a Toshiba Notebook Celeron M.
  • kono66 May 21, 2009
    same prob. tosh.sat.PS287640073
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    If you can't get into windows normally and you can't get into safe mode then you'll have to restore your computer back to factory defaults. Do you have the cd's that came with the laptop?
    President:
  • Toshiba Master
  • 1,314 Answers
Unmountable boot volume is an error you get when your hard drive is failing. You will need to replace the hard drive.
Posted on May 21, 2009
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
I have compaq C772TU Laptop. The problem is that Its hard disk warms up in 3 minutes after startup and after some time it hangs and shows a blue scree error. Please help me out to resolve this problem....
If it has the blue screen error, try to turn off the pc, remove the power cable and battery. Press and hold the power button for 5 seconds. Reseat the cables and battery. turn on the laptop.
If Blue screen occurs, turn off the pc and reseat the Hard Drive. If it still occur, then that is the time to replace the hard Drive..
May 25, 2010 | Compaq Presario 1700 Notebook
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Hello. I am on a laptop right now, but my gateway desktop is acting weird. I was playing Rome Total War, when my screen started having strange colors and the computer shut down. Everytime I boot the...
you may got infected...first run scan on the system and then reboot and see if you normally use it then try going to play again if that happen again then you need to get new video card
Nov 07, 2009 | Office Equipment & Supplies
Blue screen when trying to boot windows
you have the "blue screen of death" i had this same problem and the easiest way to fix it is to take the hard drive out and put it into another computer back up all files you want to keep on it have a boot disk for the right windows operating system on it use the boot disk with it once it is back in the right computer and then put all the files you saved back on it. the blue screen of death occurs when there is a registry error on your computer. if the blue screen of death appears again then you need a new computer.
Jun 30, 2009 | EliteGroup nForce3-A Motherboard
Pavilion ze4600 will not start
The blue screen that you see is what they call "the blue screen of death". The error that you have is Unmountable Boot Volume. This is caused by the operating system not being to load due to hard drive errors. This happens due to the computer being shutdown improperly or hard drive problem. I suggest that you contact the manufacturer of the computer so they can try and restore the computer without formatting or changing the hard drive.
Jun 10, 2009 | HP Pavilion dv6000z Notebook
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Toshiba Satellite L35-S2366 Notebook Logo
405 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
