Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Fisher and Paykel dishdrawer top drawer won't fill
RescueTech
  • 145 Answers
SOURCE: Top drawer Fisher & Paykel Dishdrawer no lights lcd
Your original problem, F4, was the machine trying to tell you that the heater plate was not working. When you turned the drawer up-side down, you may have damaged the wiring harness. If you do get a technician, call a fisher paykel authorized servicer, not an independent, and make sure you tell him about the F4 problem. A new problem has been introduced by the cleaning procedure, and both issues will need to be resolved.
Posted on Dec 11, 2008
RescueTech
  • 145 Answers
SOURCE: blocked drainage hose in Fisher and Paykel top dishdrawer DD603
Hello there..
How do you know the hose is blocked at all? It's rare for that to happen, I work on these machines daily as I am a Factory Authorized tech. You need to be careful in your approach to this, that is an expensive machine and it can be damaged by improper service procedures.
For starters, there is a flap valve on the end of the drain hose that would prevent you from introducing any sort of pressure backwards into the machine via the drain hose. For example, if you took and tried to blow air thru the drain hose outlet end, you would force that flap closed and create pressure in the hose. Also putting caustic drain cleaning substances is very, very bad for your machine and can cause some serious damage.
I will be happy to try to assist you, but let's start at the begining, shall we? What prompted you to conclude that the drain hose is 90% blocked? The first thing you should do is take out the rack, wash arm and tha large stainless steel filter plate. Next, pull the rotor up and out of the pump base (none of these procedures require tools) and make sure the grey impeller is not "freewheeling" or has become detached from the rotor shaft. The blue wash impeller on the top and the grey drain impeller on the bottom must be "one to one" meaning they are firmly connected to the shaft of the motor and turn together.
Next, check the tube or passageway in the drawer between the sump (where that small removeable filter screen is) and the pump's sump area (where you pulled up the rotor)
If you have any blockage, it will be in that tube.
There is some glitch here where I do not get notified of response to questions, so I will check back to this post.
Posted on Dec 14, 2008
SOURCE: u3 code on fisher paykel dishdrawer how to reset?
This site tells you how to reset:
http://applianceguru.com/forum1/163.html
I have the same issue and will try this tonight to see if it helps.
Posted on Feb 18, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do I reset the f1 flood button . Dd603ss
Not sure if you have managed to fix the F1 problem with your dishdrawer. This is a common problem and occurs mainly due to water leaking into the base of the dishdrawer under the bottom drawer.
But if it is occuring only in one drawer then the power filter at the base of dishdrawer is faulty and needs replacement.
Otherwise make sure the mains power to dishdrawer is turned off. Pull out the bottom drawer and stack in some towels behind it if you can to remove the moisture sitting on the base. The flood switch is located there. Then take a hair dryer and run it down behind the drawer to dry things. Push drawer back and turn power back on. Now if you cannot reach the back of the drawer then you will have to pull the drawer out from its rail. Refer the installation manual for this. See link page 7.
You need to find the source of the lead, Fisher Paykel DishDrawer Installation Instructions ManualsOnline com
Jul 05, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
After a cycle the dispenser is filled with water. The dishes are clean, the detergent is gone, but there is water filled in the dispenser. Thanks!
There is a small drain hole in the bottom of the dispenser. Most likely it is blocked. Try a toothpick or similar to unblock it.
Feb 11, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
It is likely the top panel of the drawer needs cleaning.
First turn off the mains power to dishwasher and take the plug out if accessible. Wait a little and put the plug back and turn on the mains power. If this does not fix the problem, then get clean damp cloth and wipe the panel buttons on top inside of drawer.
May 17, 2013 | Fisher and Paykel 24 in. DS603H SS...
Greetings. I have a Fisher & Paykel dishdrawer - the top drawer appears to have lost power mid cycle and the lid has not retracted - no led display - no response from the buttons. The bottom drawer...
Describethe inside of unit,any wear on it anywhere, the rack the dishes go on is it plastic coated? is it wore with rust comeing though on tips here and there?
Mar 07, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
My model number is DD603 The top dishdrawer is draining into the bottom dishdrawer. What is the code to reset the drawers?
the check valve in the bottom drawer may be clogged or defective. the two drain hoses are probly connected to become one.
Jan 20, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishdrawer, lid not retracting, no power.
By no power you may be implying there is no display etc and the swithces are not working. Most likely the controller of the top drawer has had it. The controller is mounted on the front of the drawer behind the door panel. Hope things are better than that.
Oct 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603 top drawer will not drain
Hi and welcome.
Either your hubby forgot to knock the plug out of the dishwasher connection on the new disposal, or he does not have a dual-air gap installed and the hoses to the dishdrawers do not have a high loop to prevent back-siphoning into the drawer...
Jan 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
35 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
