Question about Gateway NE56R41U Black
No boot disc - Gateway NE56R41U Black
  • 21 Answers
Try n use a friends pc, go to gateway web site. Create an emergency boot disk, start your computer up from there. When booted create a boot disk n use this to problem solve your startup problem. Which windows r u using. Normally when you switch it on if you continuously press either f5. Or f10 the computer will boot into emergency boot mode. Hope this helps
Posted on Dec 08, 2014
Inspiron 560 won't boot 2 beeps
try to use a boot up disc, if you made one, or try to boot from setup disc, restart computer and keep pressing f8 to boot to safe mode, from there you can find out why it won't boot. use a repair disc or you can make one suing another computer
Jan 03, 2014 | Dell Inspiron 530 Desktop Computer
How to restore system
im assuming you have the recovery disk
Restart the computer and press the pause/break key on the keyboard.
This key will slow down the boot process and allow you to see the motherboard BIOS access key that you'll need to press in order to access the motherboard BIOS.
Press the respective motherboard access key and check the motherboard BIOS for a boot sequence.
Change the settings in the boot sequence so the primary boot device or the first boot drive is the CD-ROM or DVD-ROM drive.
Insert the system recovery disc into the disc drive.
Restart the computer and allow it to boot up before doing anything.
A black screen should show up with the words Press any key to boot from disc CD/DVD.
Press a key to have the system boot from the recovery disc.
Allow the system to load.
Follow the on-screen instructions on how to install the rest of the operating system.
There are many different settings for you to choose.
If the operating system is just a little out of whack, you can choose to repair it.
The system recovery disc will contain important drivers and software for all the components connected to the computer system.
If you do not have a system restore disc you can search the Internet for drivers and software that are packaged for your specific eMachines model.
Restore the BIOS to their default settings so the hard drive is primary boot sequence.
This is an optional step.
You can leave the CD-ROM drive as the primary boot drive, but it will slow down the startup process by a few seconds.
hope this helps
Sep 30, 2012 | E-Machines W3503 PC Desktop
Pc not booting from cd
Hi ankushh91,
try a different Bootable disk and see if it will boot, also try you disc on a known good computer see if the disk you are using is bootable aswell to eliminate the cause of the issue.
When Booting from a disc make sure the disc is inserted in the dvd/cdrom drive once you turn the computer ON then you will see press anykey to boot to CD or disc if this shows just press any key this will boot to the Disc if it is Bootable it will show the message press anykey if the disc is not bootable it will only try and boot to the Hard drive directly.
I hope this can help,
mvincentc
Apr 17, 2012 | Lenovo Computers & Internet
How to start and format a laptop
U have to boot off the disc which is going into your bios and going to boot devices and have it boot of disc if disc is a bootable disc u should get a message saying press any key to boot of disc.. If disc is not a boot disc it will tell u to put in a bootable disc
Jan 17, 2012 | HP Compaq 6710b Notebook
Dell inspiron 1525 laptop cd rom not accepting any disc. nothing shows up on the screen when i insert the disc.
Try to use a bootable disc (usually OS discs or recovery discs). Boot to disc by changing the boot device priority into CD/DVD drive. If your unit will boot to disc, the problem is the operating system. However, if it will not boot to the bootable disc, surely, the optical drive of your unit is defective. In this case, either u need to reinsert it, or replace it with new one.
Hope this helps.
May 20, 2011 | Computers & Internet
I just purchased a Hp notebook dv2214us from an auction but everything was wiped clean off the hard drive due to California Law. I completed a self test off the Bios and everything passed. I just recently...
did you go into the bios and change the boot order to boot to the cd rom first? Then it should boot to the disc. Otherwise you may want to use any xp/vista disc do the install dont insert a cd key then once windows boots up then put the disc in and try a recovery.
Thanks,
Lee
Feb 07, 2011 | HP Pavilion dv2214us Notebook
Hi drifterk back again for another problem i need help with. okay after i reset the Bios to Optimized Defaults i cant seem to boot my windows 7 setup disc from restart it doesnt pick up any disc's in...
For that when you power up the computer press F1 or F2 or "del" then enter in bios.
Then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
then it boot with that disk.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 24, 2010 | Office Equipment & Supplies
Advent notebook not booting.
ahh..yess...that can happen...try it with the restore disc, and press F2 while booting up. This will take you to the settings and bios, where you can disable the hard drive, and make the cd the boot device..do you know of this area in the computer?
Oct 14, 2008 | Computers & Internet
How to use my recovery discs?
They should be in a bootable disc format and numbered. You will want to either enter the boot menu at start up or set the CD drive to boot before the hard drive in the boot order from the bios or set up. If you go from the boot menu then you will put the disc in the drive and select the CD drive. If you do the boot order, you will need the disc in the drive when you start the machine. If the discs are numbered, start with number one, boot it, and follow the directions.
Jul 24, 2008 | Computers & Internet
K, now it wont boot from disc
Try this out hit f2 repeatedly with the disc inserted when u restart ur pc get into the BIOS screen and select Boot in that select primary boot as cd/dvd drive then save and exit.Now it should restart and boot from the disc..
Goodluck..
May 11, 2008 | VIA ASRock K7VM3 Socket A/...
Gateway NE56R41U Black Logo
188 people viewed this question
Top Gateway Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Gateway Water Sport Expert? Answer questions, earn points and help others
