Question about Estate Washing Machines
Take back off - Estate Washing Machines
X box cheat codes ( mortal combat deception)
Ashrah's First Fatality Down, Down, Up, Up, Y (close) Ashrah's Second Fatality Forward, Down, Forward, Down, Y (sweep) Baraka's First Fatality Forward, Up, Down, Y (close) Baraka's Second Fatality Forward, Down, Back, Forward, Y (sweep) Bo Rai Cho's First Fatality Down, Up, Forward, Forward, Y (sweep) Bo Rai Cho's Second Fatality Up, Back, Forward, A (sweep) Dairou's First Fatality Down, Up, Back, Back, X (sweep) Dairou's Second Fatality Down, Down, Back, A (close) Darrius's First Fatality Up, Down, Back, Forward, A (sweep) Darrius's Second Fatality Down, Forward, Forward, Up, X (close) Ermac's First Fatality Down, Back, Back, Down, A (sweep) Ermac's Second Fatality Back, Down, Back, Down, B (sweep) Havik's First Fatality Down, Forward, Forward, Up, B (close) Havik's Second Fatality Forward, Forward, Forward, Back, Y (sweep) Hotaru's First Fatality Forward, Up, Back, Down, X (sweep) Hotaru's Second Fatality Down, Forward, Back, Forward, Y (close) Jade's First Fatality Back, Forward, Up, Forward, X (sweep) Jade's Second Fatality Back, Forward, Forward, Forward, Y (close) Kabal's First Fatality Forward, Up, Up, Up, A (close) Kabal's Second Fatality Up, Up, Down, Down, Y (close) Kenshi's First Fatality Forward, Forward, Back, Back, Y (sweep) Kenshi's Second Fatality Up, Forward, Back, Forward, Y (sweep) Kira's First Fatality Back, Forward, Forward, Back, B (far) Kira's Second Fatality Up, Forward, Down, Back, A (sweep) Kobra's First Fatality Down, Back, Forward, Down, B (close) Kobra's Second Fatality Forward, Back, Forward, Forward, Y (close) Li Mei's First Ftality Forward, Forward, Forward, Forward, X (sweep) Li Mei's Second Fatality Up, Back, Forward, Forward, B (sweep) Liu Kang's First Fatality Back, Back, Back, Forward, Y (sweep) Liu Kang's Second Fatality Forward, Forward, Up, Up, A (sweep) Mileena's First Fatality Forward, Forward, Down, Down, X (sweep) Mileena's Second Fatality Up, Up, Forward, Forward, A (far) Nightwolf's First Fatality Back, Forward, Back, Forward, X (far) Nightwolf's Second Fatality Down, Forward, Down, Up, Y (sweep) Noob Saibot & Smoke's First Fatality Back, Forward, Back, Forward, B (must be noob) (sweep) Noob Saibot & Smoke's Second Fatality Up, Down, Down, Forward, Y (must be smoke) (sweep) Raiden's First Fatality Back, Down, Forward, Down, X (sweep) Raiden's Second Fatality Up, Down, Forward, Forward, X (far) Scorpion's First Fatality Forward, Down, Forward, Forward, X (sweep) Scorpion's Second Fatality Forward, Back, Forward, Back, X (close) Shujinko's First Fatality Up, Down, Down, Forward, A (close) Shujinko's Second Fatality Back, Up, Forward, Forward, X (close) Sindel's First Fatality Back, Forward, Forward, Back, X (sweep) Sindel's Second Fatality Up, Up, Back, Forward, A (sweep) Sub-Zero's First Fatality Forward, Back,. Down, Forward, Y (close) Sub-Zero's Second Fatality Back, Down, Forward, Down, X (sweep) Tanya's First Fatality Forward, Down, Down, Down, X (close) Tanya's Second Fatality Up, Back, Forward, Up, A (close) Contributed By: flump.
10
Hari Kiris
After an opponent has beaten you and the anouncer yells "Finish Him!" it is time to input a Hari Kiri. Hari Kiris require no set distance unlike fatalities. To perform one simply put in the code while your character is dazed after losing a battle.
Effect Code Ashrah's Hari Kiri Up, Down, Up, Up, Y Baraka's Hari Kiri Down, Back, Up, Back, B Bo Rai Cho's Hari Kiri Back, Back, Forward, Forward, Y Dairou's Hari Kiri Back, Back, Back, Down, X Darrius's Hari Kiri Back, Forward, Forward, Y Ermac's Hari Kiri Down, Up, Up, Down, A Havik's Hari Kiri Forward, Up, Up, Up, Y Hotaru's Hari Kiri Up, Back, Back, Back, Y Jade's Hari Kiri Forward, Forward, Forward, Back, Y Kabal's Hari Kiri Forward, Up, Up, Down, Y Kenshi's Hari Kiri Down, Back, Back, Forward, B Kira's Hari Kiri Forward, Back, Up, Back, A Kobra's Hari Kiri Up, Up, Back, Back, Y Li Mei's Hari Kiri Up, Down, Up, Down, A Liu Kang's Hari Kiri Down, Down, Down, Up, A Mileena's Hari Kiri Back, Down, Forward, Back, X Nightwolf's Hari Kiri Up, Up, Up, Up, A Noob Saibot & Smoke's Hari Kiri Down, Up, Up, Down, B Raiden's Hari Kiri Forward, Up, Up, Back, X Scorpion's Hari Kiri Down, Down, Up, Back, X Shujinko's Hari Kiri Down, Back, Down, Back, A Sindel's Hari Kiri Forward, Up, Up, Down, B Sub-Zero's Hari Kiri Down, Up, Down, Up, Y Tanya's Hari Kiri Down, Down, Forward, Up, A
Jul 30, 2014 | Video Game Consoles & Games
What is this vendosupport.com?? Why is money transacted to this site without my knowledge??
mony tarnsactions with out my knowledge in vendosupport.com i went to cansel the taransaction
May 04, 2011 | Computers & Internet
How do i open the back of the watch to change the battey?
There are typically 2 ways to open the back of a watch. Some watches have a snap off cover, other are screwed on.
Snap On Somewhere around the perimeter of the back of the watch you will see a small crescent. This is the place where a small screwdriver can be inserted and twisted to remove the back.
To replace the back, simply position it evenly on the back of the watch and press.
Screw On Removing a screw on back is slightly more difficult. For these backs, there are typically a series of slots around the perimeter of the back of the watch. The best way to loosen the back is with a pair of needle nose pliers. Place the 2 tips of the pliers in slots on opposite sides of the back of the watch. Apply light but constant pressure and turn the back counter clockwise.
To replace the back, carefully replace the back with your fingers. Be sure the back is set correctly in the threads by turning the back slightly counter clockwise. When you feel the threads click into place, simply turn the back clockwise with your fingers to tighten. Once finger tight, once again use the needle nose pliers to tighten the back.
Mar 01, 2011 | Watches
How to open the back
Determine the type of case back on the watch. Set the watch face down on a soft surface and look at the back. If it has slots, it is defined as a screw-back case. If it is smooth, it is defined as a snap-back case.
To open a screw-back watch, use the metal blade of a standard screwdriver to turn the slots counterclockwise. A case-back wrench, which can be purchased at watch-repair stores, can also be used. Set the metal tips of the wrench into the back's slots and turn it counterclockwise to open.
For a snap back case, place the metal blade of a standard screwdriver in the indent between the watch and the case. Gently apply pressure to lift the case up and off of the watch.
Close the case back by setting it back onto the watch. For snap-back cases, line up the indent on the side of the watch and press gently on the case back to close. For screw-back cases, use the screwdriver blade or case-back wrench to turn the slots clockwise, thereby closing the case shut.
Feb 06, 2011 | Bulova Watch
Adapt a Hassie 500el/m to a Imacon ixpress back V 4.7
The Hasselblad ELM does not need adapting to use the Imacon or hasselblad digital back  the following backs fit on the ELM and can be triggered with a cable that should be supplied with the back.
Hasselblad V96c 16mp square format back  Hasselblad CFV 16mp square format back with CF slot Hasselblad CFVII 16mp square format back with CF slot + larger screen
the following backs will work but need to have a V adapter plate fitted to the back
96c 16mp square format back  132c 22mp 645 format back  528c 22mp 645 format back with Multishot option CF-22 22mp 645 format back with CF slot CF-22 MS 22mp 645 format back with CF slot & Multishot option CF-39 39mp 645 format back with CF slot CF-39 MS 39mp 645 format back with CF slot & Multishot option
When fitting and digital back to an older camera the best advice is to get the camera body serviced to ensure that the back mount is correct as the digital backs require a better fit than the film backs did. If the mount is off it will cause back or front focus.
Mar 16, 2009 | Hasselblad 503CW Medium Format Camera
Crossing of wolves and chicks
Hi, try this bro!
First step: Move 1 wolf and 1 chick
Second step: Bring 1 chick back
Third step: Move 2 wolves
Fourth step: Bring 1 wolf back
Fifth Step: Move 2 chicks
Sixth Step: Bring 1 chick and 1 wolf back
Seventh Step: Move 2 chicks
Eighth Step: Bring 1 wolf back
Ninth Step: Move 2 wolves
Tenth Step: Bring 1 wolf back
Eleventh Step: Bring 2 wolves over Take the 3 wolves first kick them until they run away go back and take the chicks across (That is if the wolves havent killed you)
Nov 23, 2008 | Nintendo Professor Layton & the Curious...
Washing Machines Logo
155 people viewed this question
Top Estate Washing Machines Experts
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
