Sanyo tv no sound
I have no sound on my tv that is hooked up through cable but I do have sound on the play station. Can you help
Tv i=has no sound, i unplugged it reset to factory settings and still no sound please help
Posted on Jul 02, 2014
5 Suggested Answers
jimbo4026
  • 50 Answers
SOURCE: ds27510 tv sanyo
are you using the orginal remote that came with the tv? It should have a input button close to the power button
Posted on Nov 20, 2007
SOURCE: sanyo tv
Try to put DVD conection to your tv if it works normal no problem to your tv, but if sound dosnt work your tv has audio input problem maybe looseboard, or maybe you check the setting for audio.
Posted on Apr 24, 2008
andyroid85
  • 7 Answers
SOURCE: sanyo tv # DS35580
check the 33vdc on one of the pins going into tuner,
if present, open tuner box and check all the grounds
around the edge for bad connections
Posted on May 02, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
Two stations are coming in spanish but only during football games.
tray to re search your tv set but look the tv standard for audio
Nov 25, 2013 | Sanyo Televison & Video
Help! My not so electronically inclined husband has a Sanyo stereo system (came with the marriage, the manual did not)..we just bought a HD Vizio, I want to hook it up to the Sanyo, but no manual and he...
I personally do not follow the route-everything-through-the-receiver model. Sound - ABSOLUTELY; Video? Nah.
Is the Sanyo a SOURCE of sound? More likely it's just the light show at the end of the Cable Box, which IS a source of high-end audio. Treat it as any digital source like a CD player for audio.
The Sanyo NEEDS a basic video output to the TV so you can use the Sanyo's menus. The Vizio NEEDS basic audio from the Cable Box (for watching news and other lo-fi content); and the absolute BEST video from everything.
As far as manuals for the Sanyo go, a model number would help.
Maybe run it by the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usersmanualguide.com
Mar 30, 2011 | Audio Players & Recorders
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
Dec 05, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
New sanyo hdtv and old vcr...can't get menu to appear on screen
there is an input or input select button that gives you cable,hdmi and video composite,to run the vcr. hook up cable and put the tv on channel3 to make sure that works first,then play with the rca cables. keep in mind a tape has to be playing,the new tv have a signal sense circuit,if there is just "snow" you get a blue screen
Jul 22, 2009 | Goldstar GVR-E435 VHS VCR
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Feb 27, 2009 | RCA Televison & Video
Sanyo vcr mod 900 does not play cable tv stations above channel 13
Check your set-up screen for something like a choice of HRC, IRC. Those are the different cable standards. Select one, and if that doesn't work, try the other. Of course if you have digital cable-you are out of luck and must use the cable companies converter box- and there is no way around that box.
Jul 02, 2008 | Sanyo Televison & Video
Play Station 3
Please tell me what cables you are having...? audio/video cable...?
Mar 27, 2008 | Sanyo DS20930 20" TV
Ds27510 tv sanyo
May 05, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Electro Med Services...
