Question about Zanussi ZWF1430W Front Load Washer
Machine spinning very slow and after 16 minuts stop but not spinning at full speed ?
Machines 510
these machines can get seized bearings, which can stop the bowl from turning at full speed. probably the motor after this.the clutch should affect full spin speed only if it's worn. this fault can be a timer issue also.
Nov 17, 2013 | Hoover Washing Machines
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Hi I Have a IZ 161 W goes through all cycles until spin starts in slow spin but thats it and the time does'nt move basically it is not spinning to full speed . appreciate any advice regards Sarah
The speed of spinning in the washer depends on the weight of the linen in the machine. if the machine is not fully loaded it will create an inbalance and the motor control unit will sense this and hence spin at a low speed. Solution is to ensure that the machine is fully loaded with enough linen.
Oct 05, 2010 | Zanussi IZ161W Front Load Washer
Kenmore series 80, model 110-25842400, and serial number CR3353550 washing machine. I hadn't heard the machine work before the problem, and my wife said it was not working right (would fill with water and...
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Apr 12, 2010 | Kenmore 24032\24036 Top Load Washer
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Bosch Nexxt 700 spin problems
yes it could be normal if the balance control senses that the load is uneven however the same problem could be caused by a blocked filter or blocked sump hose.
Dec 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Whirlpool washer front loader model LHW0050PQ
This is not a Malber machine but the following fix has worked for the Malber washer. Try unplugging the machine for at least 2 minutes. Do not just turn it off as there is still current going to the machine .This should clear the computer. If this does not work, the imbalance may have overloaded the circuit board requiring replacement.
Nov 15, 2007 | Malber WD1000 Front Load Washer/Dryer
Zanussi ZWF1430W Front Load Washer Logo
11 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
