Question about Hyundai Televison & Video
Scrambled channel i can't acces to many of the dtv channels
SOURCE: DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Posted on Apr 16, 2008
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
  • 6 Answers
SOURCE: Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Posted on Oct 05, 2009
pabloloco
  • 2335 Answers
SOURCE: SAMASUNG 32 INCH TV FROZEN ON DTV CHANNEL 1
These are the steps to reset the DTV features and unfreeze your TV:
  1. Ensure the tv is in analogue mode, not dtv and turn it off.
  2. With the remote: press info, then menu, then mute, then power. These buttons need to be pressed sequentially, not all at the same time, and in quick succession. A menu will appear on the tv.
  3. Navigate to the reset option and press the left arrow key on the remote (or press the enter/ok button). The tv will reset itself and turn off.
  4. Turn the tv back on & it'll re tune all its channels. DTV should be working again.
I hope that helps.
Posted on Dec 26, 2009
Scramble channel on my tevion vision hdsr 600
When you first scan either auto or manual it should ask if you want FTA or the entire channel list.some on the full list are scrambled and are pay for view.if you just want free to air then rescan manually and this will remove those channels that are scrambled.
Nov 10, 2015 | Vision Televison & Video
Vizio 32" tv led why some channels scrambled
if not the cable source then the MAIN pcb (not power pcb) controls all tuning. If you're using a cable box & some channels good/some channels scrambled, then is a cable issue.
Sep 08, 2014 | Televison & Video
I have been following instructions to convert my Polaroid to digital (via Menu; configuaration; add channels (auto) and tried new channels (auto) but keeps failing. The equipment I purchased from...
Hi, I have had the same problem with DTV. Unfortunately most of the time you need to buy set top DTV antennae to receive even a few channels. I recommend the expensive one that repositions itself for each channel ( DTV will not tune in a weak channel-it may show one from time to time after initial signal is locke in, may be a little scrambled looking for a moment or garbled speech) otherwise your stuck acquiring channels one at a time after repositioning the antenna each time.I'm sorry I didn't have better news but I hope this helps, comment let us know how we did, and good luck,Prodzilla
Apr 13, 2011 | Polaroid Televison & Video
Why has some of my channels gone and saying scrambled channel
That is how the channels are broadcast - reset the cable box and make sure your TV is digital ready to receive the signals. Some channels are just scrambled and you can't receive them. Go through your set up with your remote to channel search but some will still be scrambled because they are closed circuit or just for some broadcasts.
Jul 03, 2010 | Televison & Video
Some channels are not working, says scrambled or bad channel
hi pinkzz you must delete the channels that are bad/scrambled before you rescan because the box allready sees that the channel allready exists
Apr 21, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Ex 5100 pvr scrambled channel problem
you need the scramble code and/or filter for whatever specific channel you are trying to recieve. there is no legal way to get this except from the subscription line for whatever channel it is you want.
Aug 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox box sl1000 channels are scramble
Hi just got the sl 100 eurovox, its saying channels are scrambled. How do i fix this
Mar 06, 2009 | StarTech.com StarView SV211K 2-port KVM...
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
HD Picture is Scrambled, but Has Sound
I had the same problem
you have to set up the componant on DTV.
the signal my be hd 1080i and the only connection with componant that can support this is the DTV port.
the other componant connections only support 480,
good luck
Apr 06, 2008 | Mitsubishi WS-55711 55" Rear Projection...
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
44 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
