Question about Fisher Washing Machines
LW085K f&p washing machine cold water fills very slowly
Hot water fills fine but cold water wash takes 2 hours
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
AlmostBob
  • 550 Answers
SOURCE: kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Posted on May 25, 2008
futureloginn
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Which is hot & cold inlet connection
If you want to connect up a washing machine that uses hot and cold water but you only have a cold water supply (such as in a basement or garage) you can use a Y Piece connector to connect the hot and cold fill hoses to a single cold water supply (external link to 4Washerhelp spares).
The washing machine will then work OK. Simply screw the Y-Piece onto the tap, and then screw the hot and cold fill hoses to the Y-piece and connect the other end of the fill hoses to the washing machine. (You may also be able to buy this part from a DIY store like B&Q)
If you don't connect a water supply to the hot valve (and simply connect the cold water hose to the cold valve leaving the hot valve with nothing connected to it) then some wash programs may not work as some programmes only fill with hot water. However, some washing machines will work OK with only the cold fill hose connected. You can always try it and see. The worse that will happen is the washer could either stick on the odd wash programme or may abort on some. If you do this though it's possible for water to drip out of the hot valve on some machines during fill. It's best to use a y-piece if possible.
The fact that you have connected cold water to the hot valve is irrelevant, the washing machine will not know any different and will just heat the water up to the correct temperature. The washing machine may use slightly more electricity but if it's less than 10 years old it shouldn't be significant unless you use a lot of 60 or 90 degree washes. On 40 degree washes, manufacturers argue it's more efficient to fill with cold water only and slowly heat up the water to 40 degrees.
Apr 30, 2011 | Washing Machines
My washer will fill with water during the wash cycle just fine, but during the rinse cycle the water just trickles in. The water lines seem to be fine. What else could be causing my problem?
usually the wash is a mix of hot and cold and the rinse is just cold, that said, it is most likely a problem with the cold water supply. check to make sure the cold water valve is all the way open and the hose isn't kinked. If those are ok turn the water supply off and remove the supply lines on the machine side, you will see a screen inside the washer that may be clogged with sediment. If so, just clean it out and put it back together. You may also want to run a wash cycle on cold only to see if it fills slowly for the wash cycle. If it does fill slowly on cold you have low pressure on the cold side.
Jan 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Received washing machine with no instructions,favourite program show preference for warm water wash,when I go to use cold wash it fills very slowly and then beeps show warm water light flashing I need to...
You MAY have a faulty cold valve (Not unusual) Or low water pressure. If the machine will fill ok on 'hot' but has a problem on 'cold' then you probably have a faulty 'cold' valve.
Do not change wires to 'hot' valve, as there is a difference..
Good luck....Nomess
Aug 04, 2010 | Fisher and Paykel Fisher & Paykel Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Why did my LSE7806ACE WASHER STOP FILLING
Hi…
If I get you correct, the hot water is not coming into the machine or it is not working at all.
Let me know
Thanks
Smith
Aug 13, 2009 | Maytag LSE7806A Top Load Stacked...
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
