Question about Winter Sports
Barrecrafterski rack lost key - Winter Sports
How do i start a 2002 chevy without keys
call your Chevy dealer they can get new set of keys, by using the VIN # number of the vehicle,,it won't be cheap ,,, you
will have to prove owner ship....the cheaper way will be get a new
cylinder switch,, from you local auto parts,,, the cylinder switch
come with a new set of keys.......good luck.....
Mar 02, 2015 | 2002 Chevy Astro - Passenger van, with...
Tip
Have a problem with your Thule rack or product?
Thule Racks can be complicated and sometimes the instructions are missing, forgotten or lost. By following this link to Thule, you can choose whatever product you have and get either a new manual (free-PDF) or any other technical specification you might need.
There are also links to the following if you can not find the answer you seek. You will be able to access:
Spare parts and Technical Information:
Key and Lock Cyclindar Information:
The Customer Service Center:
Product Registration:
on Dec 10, 2010 | Cycling
Barrecrafter ski rack lost key
Lock Smith can do a Tap and File (Insert a Blank and rotate it and File to get the lands and grooves to get it done (Time Consuming) and Cost Extra Money
Try a Different Locksmith
Jan 25, 2014 | Winter Sports
I was driving making a turn It felt like I lost control of car the steering wheel was hard to turn like locked up. had to put it in N and park it Audi a6 1996 I do need to change water pump but it was...
Check the power steering fluid level and add fluid if it is low. Check to see if the steering rack is leaking. You can check it by removing the tie rod boots to see if fluid comes out. Make sure the belt is tight. If the pump works and no leaks, you may need steering rack replacement. If you do need to replace your Steering Rack, this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/power-steering-rack.html
Jul 22, 2013 | Cars & Trucks
How do I open Yakima Skybox Pro Cargo Box without the key
How can I open a Yakima without keys. I lost my keys..
Mar 12, 2012 | Yakima Skybox Pro Cargo Box
My 2003 ford focus lost it's power steering, mechanic replaced the rack and pinion thing - lost steering again and now the mechanic says it is the power steering pump. The rack and pinion was replaced...
if the rack and pinion was not leaking or causing problems. then he may of made a wrong move! if the rack was fine before, and you just lost power steering. then it is most likely the power steering pump or the lines that go from rack to the pump. good-day ! if a rack goes bad, you will get a bad steering problem or just bad steering.
Aug 23, 2011 | 2001 Ford Focus
Bought a barrecrafter car rack off craisglist...i bought it with no keys because the ownr lost them...i need a replacement
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
Jan 05, 2011 | Barrecrafters /sportrack, Sx-12...
How do the cross bars come off on the roof rack?
One side of each crossbar has a key that engages the removal screw. If you have lost this, then perhaps the local Subaru dealer can help. Otherwise, you will have to drill the key lock out.
Nov 21, 2010 | 1998 Subaru Forester
I have lost the key to my Barrecrafter ski rack #007 Who should I contact to find a replacement?
Find a dealer in your area, it should have a number on it for them to get you a replacement. OR, most locksmiths should be able to do the job while you wait.
Feb 05, 2010 | Barrecrafters /sportrack, Sx-12...
Toyota rav4 removable roof rack
also you need 4 rubber pad's looking is attached on the base of the racks, and 4 clips (conected the roof rack w/ the brackets on the roof on you rav) and the key (is the roof rack are locked).
Mar 26, 2009 | 2000 Toyota RAV4
Winter Sports Logo
77 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
