Question about Protron PLTV-3750 Television
Blue screen, power light stays red. Reset on back does not help.
I get a blue screen with NO SIGNAL in the center, yet the power light remains RED. I have used the power switch on the back several times with no result. This has happened several times in the past two weeks, but using the reset on the back has always cured it; not this time. I have a 37" Protron model PLTV3750 Hope you can help. Thank you.
SOURCE: Blackout, High Pitch Squeel
Funny to see this because this is exactly what is happening to my 32 inch TV and I was researching to see if some one else had this problem and right away I find this, I've had my set for over a year now, and I have no solution at this time, but I will continue to research this, I figured that Protron would blame the cable company,that's what company's with crappy products usually do. Blame someone else.
Posted on Jun 03, 2007
SOURCE: I"m trying to use my Protron Pltv 3750 as a monitor for Mac Mini
mine only works with 1024x768 resolution.
Posted on Jan 16, 2008
  • 133 Answers
SOURCE: what is the code for my tv what numbers for my atlas universal remote control
I own a One-for-All universal remote, and my booklet says that the setup code for a Proton TV (without a built-in DVD or VCR) is 0178. I can not guarantee that this number will work with your remote, but it is worth a try.
Posted on Jul 10, 2008
  • 4 Answers
SOURCE: where is the serial number on the pltv3750
its on the center label on the back of the display under the bar code it states above it "S/N AND DATE"
Posted on Feb 24, 2009
SOURCE: Protron 37" TV screen/picture problem
i have a poula 2150 chain saw i replaced my primer and fuel lines but the lines 1 goes to the tank leaving with no place for all my linesr all
Posted on Oct 09, 2009
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
Protron pltv no tv signal
Unplug it for about an hour to see if it will reset itself first. This TV is known to have power supply problem, but yours has 5vdc standby working because the red light on the front is on, and the screen is also lited up blue. The problem can be the processor in the main board and will need more troubleshooting if that is the case.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Jul 11, 2010 | Protron PLTV3250 32 in. LCD Television
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Red on/off indicator light never turns off
I had that same problem intermittently for about six months. Now I have no picture, just three small vertical lines in the center of the screen. One red, one green and one blue. Can anyone help? I know its outdated but I'd hate to throw the set in the dumpster if it just needs a little mainentance.
Jul 05, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Mar 13, 2008 | Aspire Digital AD-8091 DVD Recorder
Televison & Video Logo
51 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
