Question about Euro-Pro Shark 9110 Sewing Machine
Lcd does not display it scrolls - Euro-Pro Shark 9110 Sewing Machine
How to adjust my apple sreen size ?
Well this is tricky, there is a simple answer, but it may not be the one you are looking for. SysPrefs>Displays Resolution is set there, but there are different looks to that depending on which computer you have running which operating system.
If your intention is to make things larger and easier to see, this might help, but may also give you a resolution warning whenever opening iPhoto or iTunes for example. The warning is basically telling you that the interface may place certain buttons or tools outside the resolution parameters, so that you may not see them. That is not a good thing. You may not always need your resolution set lower, try to find the middle ground with resolution settings, but remember these tips if you are having difficulty seeing the details when the pixels are so fine. Command +(=) or - works in someplaces to increase or decrease the size of the content. Need a magnifying glass? SysPrefs>Accessibility "Zoom" Check the box "Use scroll Gesture . . ." Scroll up or down normally, but when Control is held scroll 'in and out' Easy to remember, it rhymes, 'Control and Scroll'.
Apr 04, 2014 | Bernina Artista 180
Janome 6125qc
Although you have selected a zigzag have you also set the stitch width and length manually as required? Some stitch types have restrictions on the width you can set so it's important to know which these are.If you don't have the instruction book it is available as a free download from Janome. Go to www.janome.com, click on the Machines tab then choose 'retired' and scroll down until you find the 6125QC - the link to the user guide is in the top right corner of the specifications tab.
Nov 02, 2013 | Sewing Machines
Elna 9006 lcd backlight is off
Try this link for an affordable solution to repairing your Elna Envision 9006 Display Back Light.
Elna Envision 9006 LCD Backlight Replacement Kit
Oct 14, 2012 | Elna 8007
LCD DIsplay will not display
since it's a babylock the machine needs to be taken to a sewing
machine shop so they can check the diaplay to see why it's not
working.
Jun 06, 2012 | Baby Lock Ellure
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jun 22, 2010 | Janome 8080 Computerized Sewing Machine
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Jan 15, 2010 | PfaFF Tiptronic 2030
Hello! Our Huskylock 1002LCD machine is speaking
Hold in the "A" button and the up arrow button at the same time and turn the machine on, you can then scroll through the different languages the machine can display using the "A" and "B" buttons.
Oct 06, 2009 | Husqvarna Sewing Machines
Sewing machine LCD display not lighting up
Check this Link
Sep 18, 2009 | Janome Sewing Machines
Display screen has gone out on Janome 8000 machine.
The part is an LCD screen that needs to be rebuilt by the Janome Company. You will need to take the machine to a Janome dealer for this repair because Janome only sells to it's Dealers.. Plan on spending more than $300.
sewman7
Dec 11, 2008 | Janome 8080 Computerized Sewing Machine
Euro-Pro Shark 9110 Sewing Machine Logo
24 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
