Question about Pioneer Sx-2300 Am/fm Stereo Receiver With Graphic Equalizer
Unable to get any sound other than static from the speakers when trying to play the receiver on a pioneer sx-2300 stereo receiver. the volume has to be turned all the way up just to get static.
Cannot get any stations on the receiver and only static out of the speakers. the speakers work fine with the cassette and cd player. also the volume has to be turned to the max just to hear any static when trying to use the stereo receiver.
SOURCE: Pioneer Multichannel Receiver VSX-D508 (including cd player & tape deck)
receiver on the screen displaying power off
Posted on Apr 15, 2008
starlet4life
  • 89 Answers
SOURCE: Pioneer automotive stereo cd player error 11
Error 11 is probably the laser...;)
Posted on Sep 26, 2008
SOURCE: avh-p5700 pioneer
You should try disconnecting the unit from you vehicle for at least 5 minutes to let the eprom reset, when you connect it back in hit the reset button and she should restore herself back to factory settings. If this does not work im afriad your going to have to take it for repair.
Posted on Sep 30, 2008
SOURCE: i have my pioneer djm 600 for about 5 years. I
You've got dirty pots mate! You need to clean all the dust and **** from inside the sliders and the circular trims. The plastic shaft ALPS pots in the DJM600 don't have a sealing bush so if you pull the knob off and spray some "no-residue contact cleaner" down the shaft you may get it to the bottom. DO NOT use WD40 as that leaves an oil and will clog the pots (as the oil will eventually mix with new dust and make a gloopy paste) This would then break the sweeper contact with the resistive surface.
Virtually all the ALPS pots on the 600 are stereo so as you have lost a channel some of your pots have lost connection already. Cleaning may help but if not you may need to strip down desolder the troublesome ones and replace (or if your feeling brave bend open the tabs and clean internally)
Don't worry though. I got the right cleaner (electronic use no-residue stuff) from a car accessory shop and it all started working again without opening her up.
Posted on Mar 20, 2009
  • 3247 Answers
SOURCE: My Pioneer Receiver (SX-255R) won't
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Posted on Jan 02, 2010
Bought a Pioneer SX580 receiver, everything lights up but can't get any sound
Do you know for sure that it works okay? i.e. did you hear it playing through speakers before you parted with your cash?
Have you checked for buttons that switch the speakers on/off (Speakers A/B A+B) or a manual mute button?
Sep 09, 2014 | Pioneer Vintage Sx-580 Stereo Receiver -...
Kenwood receiver speakers static pop
Your volume emitter needs to be replaced. And or the resisters on both sides of it.
Apr 18, 2012 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
I have tv hooked up to the pioneer but the TV will not play its sound through the speakers? what Am I doing wrong? I have the DVD hooked to the Pioneer and it works fine.
Is the unidentified TV a sound source from the SX-315's perspective? Is it's audio output enabled whene the TV volume is down? Would the Cable Box be a BETTER source?
Jul 26, 2011 | Pioneer SX-315
My Pioneer Receiver (SX-255R) won't play anything. I only have a CD player connected to it. The screen only says "Muting." I've tried unplugging it for 30 minutes and re-connecting. Still says...
Suggestions
Good luck
Dec 26, 2009 | Pioneer SX-255R Receiver
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Mar 02, 2008 | Audio Players & Recorders
Car stereo static
Sounds like you may have an output transistor/module about to go out.
May 10, 2007 | iLO XM-MP3-CD Car Stereo
Pioneer Sx-2300 Am/fm Stereo Receiver With Graphic Equalizer Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
