Question about Razor Dirt Quad Bike
Rear sprocket turns with motor but rear wheel is unresponsive
2 Suggested Answers
SOURCE: Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
Posted on Nov 03, 2010
2008 harley road glide rear wheel does not tuen
If the rear sprocket turns but not the wheel then the sprocket fasteners could not be securing the sprocket to the hub and you must have sheared sprocket bolts.
Sep 29, 2014 | 2009 Harley Davidson Road Glide CVO Base
Chain adjustment
Just a guess, but beings you didn't give YEAR/MAKE/MODEL, that's all I can do.
IF it's the rear drive chain you're talking about (as opposed to the primary chain), get rear wheel off the ground.
With bike in neutral, rotate rear wheel until you find the tightest spot of the chain in the middle between the rear sprocket and the transmission sprocket.
Loosen axle nut, adjust rear axle adjusters evenly until slack is within spec.
Rotate rear wheel in normal direction of travel and see that chain is tracking true on sprocket. If not,adjust as needed with axle adjusters.
IF mechanical rear brake (instead of hydraulic rear brake), adjust brake.
Oct 16, 2013 | Motorcycles
The pedals will turn but the wheel does not
The rear set of gears, called the "Freewheel" are shot, and need to be replaced. You can find another wheel, but this will probably prove to be difficult, or you can pay for a new freewheel or your bike shop may give you an old one for a discount.
Good luck
Joe
Aug 29, 2011 | Cycling
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
The sprocket on the rear wheel is frozen. The bike cannot coast as the petals keep turning when the rear wheel is turning.
If I were fixing this problem, the first thing I would do is soak the sprocket with WD-40 or CRC. After a day, gently tap the sprocket in an attempt to free it. Soak it again and so forth. If it doesn't come free in a few days, it may be better to replace it. What condition is the chain in of the rear sprocket is frozen to the wheel?
Thanks for your interest in FixYa.com
Feb 10, 2011 | Cycling
Can you change tranny gears to decrease rpm's on highway? Or maybe change sprockets.
You can add teeth to the front sprocket or take teeth off of the rear sprocket. In the case of your bike , I do not think there is a 17 tooth front available so your best option would be to shorten your chain and drop from the 44 tooth rear sprocket to 40 tooth or a 36 tooth rear sprocket. That would be like adding one or two teeth to the front sprocket. Your stock is 16/44 so decrease from there. Be sure to ID your chain, get a chain breaker, and a new master link.
Feb 06, 2011 | 2004 Honda VT 600 C Shadow
When i push the thumb control down the motor comes on and the chain turns but the rear tire does not what is causing this? thank you
If the sprocket and chain turn on the rear wheel, it sounds like the freewheel on the rear tire is faulty.
Sep 28, 2010 | Razor E300 Scooter
Early model Razor MX-500. Replaced motor, control module to 5 wire, and throttle. Still, clicking inside controller but will not send power to motor. What's up?
the back wheel won't move it try to move but it won't it's making a loud noise.every time you give it gas.what could that be...
Dec 26, 2009 | Razor MX500 Dirt Rocket
Rear wheel won't turn when pedaling
hi there,
put your bicyles on upside down position,wheel should on top so you can work freelywork on ,then rotate the pedal to check what the problem it should be freely rotating,check break pads if it was engage even w/o pressing control.release brake cable wire to loosen.if not in the break,check the sprocket gear if connecting to the chain belt,check your sprocket release lock,if damage replace sprocket, check the bearing of the two wheel center shafting if worn out replace bearing,on front wheel there are two quick release nuts,loosen and pull out wheel and loosen all nuts and lock plate bearing,pull out shafting with the bearing,examine mostly bearing worn out also shafting in some occasion its worn out also,possible if you want replace one set center shafting and bearing ts not costly,on rear wheel with sprocket it different to disconnect,beacause there is sprocket,you should dismantle the locked plate and lock nuts of sprocket before the shafting assymble same procedure now on front wheel when after disconnecting sprocket on rear wheel.hope this will guide you and solved your problem have anice day.
Jul 14, 2009 | Mongoose Cycling
May 10, 2009 | Razor MX500 Dirt Rocket
Razor Dirt Quad Bike Logo
78 people viewed this question
Top Razor Rock & Ice Climbing Experts
Bill Boyd
RatanbssBD
Level 1 Expert
Are you a Razor Rock and Ice Climbing Expert? Answer questions, earn points and help others
