Question about Microwave Ovens
Microwave the plate not turning
My microwave the turnable plate not turning, and it is a build in, how can I fix it?
  • 883 Answers
Remove power. turn it upside down. remove access cover and determine if there is a mechanical obstruction...could even be belt driven with a broken belt.
Posted on Oct 19, 2007
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Samsung motor slipping
If you are talking about the turnable motor that rotates the plate, that motor will need to be replaced.
Apr 02, 2012 | Microwave Ovens
Whirlpool Microwave 20C turnable plate not turning,not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Troubleshooting Tips
Nov 24, 2010 | CDA CM1 Microwave Oven
The microwave timer runs but turnable plate doesn,t rotate and the heating elements doesn't comes on
you need a new microwave. There are no heating elements in mocrowaves just micro-waces. It only heats moisture it does not heat objects. It is to dangerous to replace the actual device that heats liquids.
Jan 24, 2010 | Emerson Microwave Ovens
Turnable plate isn't working
in order to be 100 % sure
you would have to check voltage to the motor while its suppposed to operate
take off the bottom 6 screws, you might need whats called a safe t, a torque wrench or star with a hole
most use phillips,
drop the bottom, you should see the turn table motor
disconnect the two leads and connect them to a voltmeter,,,
turn the unit on
you should read voltage to the meter
if not the problem is in your control board and will need to be replace
if you do read voltage and the motor is not turning
you will need to replace the actual motor
either way its a pretty simple repair and can be done without taking the unit dwon
Oct 24, 2009 | GE XL1800 1100 Watts Microwave Oven
Turnable plate not turning
turn table motor sound like.
Sep 14, 2009 | CDA CM1 Microwave Oven
GE microwave Turnable turns on opening the door
Thanks for the photo of the label!
It shows the FCC ID number, which I used to find schematics at the FCC Web site.
The problem is a shorted primary interlock switch.
This is the door switch which has two black wires connected to one terminal and a black and a blue wire connected to the other
See these files for help:
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Jan 18, 2009 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
580 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
