Question about Calphalon Quick Brew 12-Cup Coffee Maker
Cofffe maker does not brew - Calphalon Quick Brew 12-Cup Coffee Maker
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
Water is not pumping.
Hi, it seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Apr 26, 2011 | Saeco Talea Ring Plus Espresso Maker with...
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
2 hours to brew
Bad temperature sensor, possibly. Unless you are good with electronics repair it's probably not worth paying someone to fix this. Buy a new one at wal-mart.
Feb 25, 2007 | Emerson EM83701 Coffee Maker
Calphalon Quick Brew 12-Cup Coffee Maker Logo
19 people viewed this question
Top Calphalon Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Calphalon Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
