Question about Sony Bravia Kdl - 60Ex700 60 inch 1080P Led Hd Tv
Does the Sony kdl-32ex400 have a reset button the tv shut off and now it want turn back on
3 Suggested Answers
  • 53 Answers
SOURCE: 40xbr2 bravia kdl sony LCD tv. The screen shuts
Problems relating to the automatic turn on and turn off of a set like this usually point to the main board being an issue. For this set, I believe Sony refers to that board as the "AU" board.
It's probably not the G/Power Supply board, especially if it turns itself on. Power supplies will turn a set off, but rarely--rarely--turn itself on.
If there's no kind of extended warranty involved here,
you could be looking at $500.00 for parts and labor to repair this kind of problem.
As always, try any software/firmware updates Sony might have available on their website prior to pursuing a repair visit.
Posted on Jan 22, 2010
gopakumarg43
  • 75157 Answers
SOURCE: Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Posted on Aug 22, 2012
Sony Bravia no sound no video?
its need tv up date soft ware please up date your tv
Jun 10, 2015 | Sony BRAVIA KDL32EX400 32" 1080p LCD TV...
How to fix problem with power supply sony klv 32EX400 ,showing only 3.3v stby
Please specified problem,Check BackLight Inverter Board look for any burnout component,then look power supply,generally Power supply shows only 3.3 or 5v in standby condition,after initialize by control engine you may able to check several power rails.
May 13, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
32ex400 lcd tv hdmi no work
The most likely solution to your problem is to go into the tv's settings and verify that the input (which ever the the number is) is not set to "skip" as that will make it appear as if it doesn't work. Just change the label for that input to anything but "Skip".
Good Luck!
Rich Lilja
Dec 18, 2013 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Sony kdl52nx800 will not turn on indicator light blinks 5 times
While looking found this:
Found this service bulletin for sony KLD
KLV40EX600 not austalia model but think KDL will be similar
Model No: KDL-32EX400 KDL-40EX400 KDL-32EX500
KDL-40EX500 KDL-46EX500 KDL-55EX500
KDL-32EX600 KDL-40EX600 KDL-32EX700
KDL-40EX700 KDL-46EX700 KDL-52EX700
KDL-60EX700 KDL-40HX700 KDL-46HX700
KDL-55HX700 KDL-40NX700 KDL-46NX700
KDL-52NX800 KDL-60NX800
SUBJECT: Counter measure for Intermittently 5 times standby LED blinking
SYMPTOM: Customer may report that intermittently after AC OFF/ ON (or Deep Standby/ ON), TV will shut down with LED blinking 5 times. If set is placed in Standby, then On, symptom will re occur. If AC is removed, set will work normally when AC restored
CAUSE: Timing mismatch of I2C communication causes interrupt signal inside TV. This causes TV to shut down with error 'Standby led flashes 5 times'
SOLUTION: This is a user correctable issue -
Where possible, please refer customer to Sony Website -(or ) and search for relevant model to download correct update. If the unit is in Workshop, please perform update as per Instructions.
Dec 14, 2012 | Sony KDL52NX800 52 in. TV
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
How do i stop text showing under the picture
go to your menu and shut off any closed caption cc
Jan 17, 2011 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Functional Noise
Not normal, top right back corner have inverter board and power supply board. It may be the transformer making noise. you are better to exchange it.
May 26, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
T.V dosen't work with battery or inverter
The TV use 110V 60Hz sine wave AC, after rectified will be 156V DC, your inverter may be output 110V square wave AC, after rectified only 110V DC, it is too low for the TV work. except it can adjust to 155V.
May 18, 2010 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Nov 30, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia Kdl - 60Ex700 60 inch 1080P Led Hd Tv Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
