Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
Francis Francis X1 - Cleaning lime from tank
Have had a Francis Francis X1 espresso machine for almost 10 years. Wondering how to clean the lime build-up from the internal heated water tank.
  • rjm156 May 22, 2009
    do you mean - brew CLR, then brew vinegar, then brew water? Not sure what you mean by "CLR rinse" as this is an espresso machine with a sealed tank.
  • 2,005 Answers
CLR rinse followed by a vinegar brew then a clear water brew cycle
Posted on May 21, 2009
  • Jim Goldsmith
    Jim Goldsmith May 22, 2009
    yes I put a teaspoon of CLR in my tank fill it up with clear water operate the eexpresso machine then I use 1/2 and, 1/2 of water and, vinegar operate the machine again and, then: rinse the tank with clear water and, mine's ready to use
"francis francis" x1 blocked - Fix Suggestions?
You can tell if the pump is working by the noise it makes. Mine got blocked with scale and I took it apart and cleaned out the boiler. It's possible; the boiler is bolted together with standard bolts (metric size). If you've got the interest the Francis Francis is easy to service; you will find a way into each part of it and clean it, and if you do it will work like new.
Jun 22, 2014 | FrancisFrancis! Coffee Makers & Espresso...
My Francis Francis x1 wont heat
You should check the temperature of the water coming out from the machine when it show that is heated. If it is lower than 90 C then the thermostat inside the machine attached to the boiler is need to be replaced. If the temperature of the water is about 90C then the problem is with thermometer, and in this case is only an accesorie since the machine can faction properly and make a good espresso.
May 21, 2012 | FrancisFrancis! X1 - Stainless Steel...
Need repair parts and repair diagram for Francis Francis X!. Water tank tube broken
Call Empire Fullfillment, they have parts lists and manuals they can email to you. You can also order parts.
http://www.empirefulfillment.com/
Feb 11, 2011 | FrancisFrancis! X1 - Stainless Steel...
My francis francis x1 has started running very slowly, it takes about 2x longer for the shot to finish coming out than it used to.
Hi
You might need a new pump or relief valve on the pressure end of the pump. There is a hose the goes back to the water tank in the back from the relief valve. See if water is going back into the tank when you are brewing?
Dec 31, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Oct 12, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis X1 overheat quickly
hey. you have calcium build up on the wands that go in your boiler so they can't messure the temp properly so it keeps heating.buy a decalcifier from any coffee site online or coffee machine sales and repaires place.
Dec 14, 2008 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
1,536 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
