Question about Mitsubishi WD-65C9 65" DLP HDTV
Fading picture rear
The TV picture is dim, faded, got darker. What do I need to replace?
CAYPIANAN
  • 227 Answers
SOURCE: Tv color fading...
change the concergence stks
caypianan@yahoo.com
Posted on Oct 28, 2008
VOTIT
  • 2071 Answers
SOURCE: Picture
Faded pictures it is caused by leaky or short capacitor it could also be power supply problem causing the optic engine and light not to work correctly, or you could have a bad DM board, or a bad light engine sounds like a bad DM board find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Hope it may help you; Regards;
VOTIT
Posted on Jan 29, 2009
  • 1572 Answers
SOURCE: The picture on my Mitsubishi ws-55315 fades away
It could be oxidized contacts in the lamp housing connector. Remove the lamp housing as you would to change the lamp (follow directions in the user's manual regarding proper cool-down first!) and check the metal contact pins or blades. If they are dull or dirty, polish them with a white pencil eraser (usually the kind found on a mechanical pencil works well). Also inspect the connections to the lamp itself. If it appears they are loose or oxidized, you will need to put on a pair of clean vinyl food handler's gloves and carefully open the lamp assembly and clean them. Reinstall the lamp assembly. Do not at any time touch the bulb with bare fingers - skin oil will ruin it!
The lamp connector is the most likely spot for intermittent problems since it is high current and high temperature. It is also possible that a solder connection on the power supply board section that drives the lamp is showing the effects of thermal fatigue (cracking and oxidizing), but you would probably see much more erratic behavior, including cutout and the flashing lamp error light in that case.
It is also possible the lamp filament is on its last legs and the vibration is knocking off loose material that reduces the light output. If that is the case, there will be gray particles visible in the lamp capsule. I've seen this with a dim tabletop projector that suddenly got considerably brighter when it was picked up and turned over while it was running.
Posted on Nov 04, 2010
  • 902 Answers
SOURCE: This is a model #
since its so old you really only chance is to replace the bulb in the machine . also you may have to replace each color board here is a link to the bulbs and the three colored boards http://www.google.com/search?q=Mitsubishi+WS-65809+bulb&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a#sclient=psy&hl=en&safe=off&client=firefox-a&hs=2uY&rls=org.mozilla:en-US%3Aofficial&biw=1280&bih=647&tbs=shop:1&q=Mitsubishi+WS-65809&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=d57722a22572de1d
Posted on Mar 16, 2011
  • 19 Answers
SOURCE: We have a Mitsubishi VS-50VA2 projection tv. The
you need to clean the dust off lamps and the guns, if you don't know how. i can walk you thru it. but i would suggest having a repair shop do a full cleaning.
Posted on Jun 24, 2011
Half of my 47" LCD Phillips screen fades from normal to dark. Any thoughts?
If it\'s a backlight issue one section will be dim and will fade darker or lighter to the other section. It is not a hard on/off line. So if it does fade to dark on one side I would suspect either a faulty backlight bulb (non-replaceable) or a failing backlight inverter (can be replaced.)
Jan 07, 2014 | Philips 47PFL7422D/37 Television
Picture seems very faded on tv it is approx 9 years old do they have main bulbs that can be replaced when picture starts to look washed out
If model number is correct the akai is a samsung; from the rear with the cover removed are three rather large black lens (one for each picture tube) that point upwards.
If the set has not been serviced for a long time clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on it.
These are the light source for your picture and if dusty the picture will be darker and dull looking.
SD TECH
Sep 19, 2011 | Akai PTH5498 54" Rear Projection...
My picture is faded and looks really dim.
you did not state the brand of your TV. I suppose this is flat panel/Lcd TV. If yes, problem is from the inverter/bulb. The bulb/inverteris defectcive that is why the picture is dim. The picture won't bright up because of this.
Inform me if you want to do the replacement on your on.
Your sincerely.
Elect_Comp
May 13, 2011 | Televison & Video
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
My hitachi ultrascan hd tvs color is fading ?
Sounds lamp in TV getting weaker and soon it will be replaced.
When dlp tv start showing darker picture then its time for new lamp to get back vivid picture.
Dec 17, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen fades occasionally. Perfetc and them fades dark for about 5 min. Is that the bulb? Howmuch is a new bulb?
Make sure that in the settings that your TV isn't setup to auto dim. I remember I had a similar problem. I think when ever a light would turn on or someone would walk near the TV it would get dim. It was really annoying. Check your settings. Good luck
Nov 05, 2009 | Mitsubishi VS-45603 45" Rear Projection...
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Screen is dim/dark picture
Time to replace your DLP lamp!  Expensive ($200 and up)!  Good luck!
Jul 31, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi WD-65C9 65" DLP HDTV Logo
10 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
