Reset imaging unit ON A XEROX 6500 - Office Equipment & Supplies
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 22 Answers
SOURCE: Is it possible to reset xerox phaser 6110mfp
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Posted on Mar 07, 2010
sayer268
  • 147 Answers
SOURCE: how do you reset imaging unit count on a 6350
install a new imaging unit.
Posted on Nov 19, 2010
  • 525 Answers
SOURCE: Please, send me the firmware for Xerox 6110 MFP
firmware to have changed only very extreme case!!! no to reset image unit
Posted on Jan 19, 2011
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Xerox workcentre 6505 reset drum
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Mar 20, 2014 | Xerox Office Equipment & Supplies
Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
Reset imaging unit xerox 7300
You can reset the imaging unit in two ways - either with a fuse, which will return the count to 100%, or in the hidden menu, which will not get you all the way to 100%. You'll find all the details about how to do it, and a lot more information about this printer here.
Nov 23, 2011 | Xerox Phaser 7300DN Laser Printer
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Please, send me the firmware for Xerox 6110 MFP for reset Image Unit;
Dec 07, 2010 | Xerox Phaser 6110 Laser Printer
Is it possible to reset xerox phaser 6110mfp imaging units
Mar 02, 2010 | Xerox Phaser 6110 Laser Printer
Jul 24, 2009 | Office Equipment & Supplies
Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
919 people viewed this question
k24674
jasbo
jasbo
