Question about Nerf N-Strike Longshot CS-6 Blaster
Rapidstrike cs 18 won't start - Nerf N-Strike Longshot CS-6 Blaster
2004 John Deere Gator CS
Hi, although i dont know what a gator cs is i would suggest you first check that your valves are opening to actually let your fuel mixture into the engine. If the valves are opening / closing at the correct time you need to check compression on all cylinders. you may have sticky rings or worse.
Sep 17, 2017 | Motorcycles
My bro started messing about with the carb setting screws on his Husky 350 and now the thing won`t start.I tried to set it for him but the limiters aren`t working so I have no idea where the H,L and ide...
run both scrwes all the way in and them back out 2 and 1/2 turns. thats a good starting point. adjust the low while idling and the high with the throttlr wide open.
Jul 11, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
Peavey cs-800 amplifier
Believe it or not, these amps have been around since the early 80s and are still available today. Contact a local Peavey dealer or Peavety directly,. These parts are still available.
Dan
Aug 25, 2009 | Peavey Audio Players & Recorders
Cs-36509 mitsubishi tv has a flicker.Makes it hard to read words. Is real bad when you first turn the tv on, but after a minute it settles down, but is still there all the time... any suggestions?
Yes first it may just be bad solder on the
flyback transformer , or the Picture in Picture
module has some bad caps . a fair shop
price is about 180-200 and it worth the repair
they are great TVs and are made to last.
ps i have repaired my mitsubishi once , and
its going strong. 18 years old .
THE OLD STUFF IS BETTER THEN THE NEW STUFF.
Mar 25, 2009 | Mitsubishi CS-36509 TV
Opening interner explorer
Try reloading explorer again by uninstalling it and reinstalling it again.
Jun 27, 2008 | Microsoft Windows 98 for PC
Nerf N-Strike Longshot CS-6 Blaster Logo
18 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Nerf Toy Expert? Answer questions, earn points and help others
