Question about Uniden Mystic GPS Receiver
Ignores incoming DSC messages
I got a mint Mystic on Ebay. Programmed my MMSI in and went out to test it. Everything worked perfectly--except it ignores incoming DSC messages--even when set to channel 70. Sends DSC messages, position reports, etc perfectly. Other radios receive and respond to my position request, etc, but my radio ignores their responses and ACKs.
I'm going to have to send it to the factory anyway because I got the brilliant idea to try a different MMSI number and see what happens--unfortunately that was past the allowable 2 entries and now nothing works DSC wise.
Just wondered if anyone else has had this problem with a Mystic.
Thanks in advance!
  • 2 more comments
  • modulo26 May 21, 2009
    Thanks for the response.
    There's a free firmware upgrade on Unidens' website, although the problem cited for the upgrade isn't the problem I'm having. Maybe there is some bug in the firmware in my Mystic causing this problem--maybe having it upgraded will do away with the problem.
    All the hardware seems to be working perfectly--what do you think?
    Again, thanks for the response.
    Thanks for checking.
  • modulo26 May 24, 2009
    Will send it to the factory--the price on the repair (or repair/exchange) is fair enough.
  • 15,935 Answers
Factory servicing is recommended - there is no end-user "simple" fix.
Thanks for using FixYa!!
Posted on May 22, 2009
    President:
  • 2,559 Answers
Yeah,but It's not common.
Posted on May 21, 2009
  • Randy Hough
    Randy Hough May 21, 2009
    I'll check it out and let you know.
I brought a Motorola VHF HT1250 radio off of eBay & I programmed it & tested it out & everything worked great for a few hours & then it beeped once & shut off & now will not come back on.
Returning the radio would be your best option. There are many factors which can cause a radio to go dead. Assuming you have checked your battery and battery contacts, and tried a known good battery, if your radio will not power up, there isn't much which can be done.
Best regards.
May 25, 2015 | Motorola Ht1250 Vhf 136-174mhz 128 Channel...
I am looking for the merlins crystal hourglass is part of a set sold at franklin mint
Did you cheek ebay? That is the place sellers and buyers meet.
You can search for almost everything there.
Jul 09, 2014 | eBay Auctions
Need to reset mmsi number
I don't think the RAY100 is DSC compatible and therefore doesn't have the MMSI programmed into it. Most manufacturers limited the number of times that the MMSI can be programmed to one (!). After that, it has to got the factory or to an authorized dealer who can bypass the restriction.
Mar 28, 2014 | Raymarine Ray100VHF 2-Way Radio
In my 06 ford fusion the "check charging system"
Please have the alternator and the battery tested, Autozone does this testing for free.
May 21, 2013 | Cars & Trucks
Change MMSI number ? simrad rd 68
Hi!
Sorry to be the bearer of bad news, but according to the Owners Manual for this unit:
http://www.busse-yachtshop.de/pdf/simrad-rd68.pdf (Page 6),
to erase a previously entered MMSI, the radio must be sent to a Simrad authorized dealer. I suppose this feature was put into effect to cut down on stolen Simrad products.
Hope this is helpful, sorry I couldn't do more for you.
Jun 19, 2011 | Simrad RD68F VHF Radio Class D DSC by GPS...
I have a model no. 32HLC56 TV. Everything seems to work fine, except the color of football fields. They come in gray instead of green. However, other things, such as uniforms that are supposed to be...
Take this tv set test it with other tv incomming tv signal cable in ur house or take another tv test this incomming broadcasting signal cable.If it is the tv,not the incomming broadcasting signal cable.The tv Tuner signal board is the causes and it is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacemennt.
Dec 09, 2010 | Toshiba 32HLC56 32 in. HD-Ready LCD...
How to reset mmsi number Raymarine 215
This secret code is for the Raytheon / Raymarine RAY 220 VHF. It may work on other Raytheon/Raymarine radios also.
Here you go:
With the Power OFF, Press and HOLD the FUNC, 16/9 and DSC keys while you power ON. Do not release the keys until you hear the audio BEEP which means your done. Then reprogam your NMSI number as per the manual. Pretty easy, hey?
Jan 28, 2010 | Raymarine Radio Communications
No chann. 70 on Uniden 525 marine radio
You can't "select" channel 70, nor can you talk on channel 70. Channel 70 is reserved for the exchange of digital data between radios.
And it is not possible to address an "emergency" (do you mean distress? or urgency?) message to an individual recipient.
Your radio is not allowing you to do any of these things because it has been (correctly) programmed to discourage you from doing things that would be illegal.
If you set up a routine call with your friend (or anyone else), you should find that once the two radios have completed their (almost instantaneous) exchange on Channel 70, they will both switch to whichever working channel you had selected, and he will get a beeping sound to tell him that there is an incoming call.
Sounds to me like both radios are doing exactly what they are supposed to.
May 17, 2009 | Uniden Boating
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Wet camera, everything works but the screen went blurred
It will likely be best to sell it and get another as the price has fallen below the fix price.
The glue that holds the screen to circuit is damaged and not fixable by the average person..
you may be able to find a screen on ebay though that could be a waste of time and money.
Dec 02, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Uniden Mystic GPS Receiver Logo
79 people viewed this question
Top Uniden GPS Experts
Shehu Pro
Shehu Pro
Martin Murray
Owen Barnes
Are you an Uniden GPS Expert? Answer questions, earn points and help others
