Question about Woodcraft Construction Kit Rolling Locomotive 3d 25
Manual for Woodcraft Construction Kit Rolling Locomotive 3d 25?
Have lights and animation, but not rolling around the track. Driving Wheels of locomotive do not move, even by hand
If the drivers do not rotate under any circumstances, the internal drive mechanism may be jammed.
Dec 10, 2013 | New Bright 384 Holiday Express Animated...
Math lessons 2 4
d = -3/8
This looks like homework. Make sure you show your work.
Oct 22, 2013 | Office Equipment & Supplies
Need instructions for St Petersburg Church woodcraft construction
I have done this model, and the answer above is correct. While it is true that many of the pieces go together without glue, glue is required to keep some from falling apart while working. It is advisable to start without glue to make sure you have things connected properly. The kit comes with a very small tube - I got some carpenters glue when this ran out.
The pieces are labeled (on the back of the box) with letter number combination. The final number for each letter is inconsistent; the letters correspond mostly to construction groups. Be aware that some pieces which are apparently spacers inside others are actually important pieces. They get numbers, but are sometimes hard to see.
Good luck with your puzzle!
Mar 30, 2012 | Woodcraft Toys
There is only one number 20 and i dont know where to connect it to.
After lots of staring and wondering, I figured this out. On the big piece that makes up the bottom center of the boat, there are labels for 19, 23, and 24, but numbers 20, 21, and 22 are missing. If you look closely, that label actually shows 19-23, 24. It means 19 through 23. You are supposed to stack up the parts labeled 20, 21, 22, 23, and 24, and connect them all to the bottom of the boat where the label 19-23, 24 appears. This worked for me - I hope it helps you or someone else who looks here when they get stuck on this same problem!
Jul 14, 2011 | Woodcraft Pirate Ship 3d Construction Kit
I have found the plans for the Seattle Space needle woodcraft construction kit 3d puzzledo not give any detail as to what pieces fit to in relation to other pieces just what reference to the front picture...
I bought space needle model #814901 and was able to put most of it together using the pattern on the back and the pic on the front. I was able to match the numbers/letters for the most part. I have ended up with an extra circle, and some numbers that have no corresponding #s. Still, the end-product does look pretty much like the one on the front. I bought this model in the gift shop at the space needle. I saw a completed one downhill in an expresso shop on the waterfront across from the sculpture garden. I go to Seattle a couple of times a year and plan to check out the expresso shop again.
Aug 15, 2010 | Toys
No Manual
hello! the best thing you should see the store from where you have purchased your kit. most stores do includes manual which are clear and really handy and accurate..giving all the details on how to do that thing.. thanks! you may fix the other parts if no manual is available through simply doing it with a common sense..you just have to join it by using stick glue.
Apr 11, 2009 | Woodcraft Pirate Ship 3d Construction Kit
Woodcraft Construction Kit Rolling Locomotive 3d 25 Logo
Top Woodcraft Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Woodcraft Craft and Hobby Expert? Answer questions, earn points and help others
