Question about Dryers
Loud noise on my electric dryer
Washwer/dryer combo. The dryer make a loud noise will drying. Checked the belt and belt tension both are good.
  • 245 Answers
There are also some support wheels under there that the drum rides on in the back and a felt guide in the front. if either of these are worn they will make noise as well.
Posted on May 21, 2009
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
Dv395etpasu/a1
The most likely cause of your issue would be a broken belt, these belts are susceptible premature wear, typically caused by the tension pulley. It's recommended to replace the belt and tension pulley. Part# 6602-001655 belt, Part# DC96-00882C. The entire home vent system should also be checked by a qualified vent company. Pleazer Appliance...
Apr 17, 2014 | Samsung Dryers
An extra loud noise starts when drying
In all likelihood the belt that turns the drum is frayed. and may need replacing. It would be a good idea to unplug it and take a good look at the belt before it comes completely off, this way there won't be any confusion about how the new one goes on.The only moving parts when it is in operation is, the drum, belt and a very small wheel on which the belt travels.
Dec 03, 2013 | Miele Novotronic T220 Electric Dryer
Dryer makes loud grinding noise when you cut it on
The dryers drum runs off a belt as you may know to spin it around to dry clothes. This belt is attached to a belt tensioner also to keep the belt snug. This tensioner has a roller with a bearing in the middle of it. Most bearings are made of brass and wear out causing it to grind
I would replace the belt & tensioner pulley as a unit. Sears will have these two parts selling together as a kit. Go online to view with your make and model number to see
May 31, 2010 | Whirlpool LER4634J Electric Dryer
My dryer is making a loud siren type noise and the drum turn is kind of clanky sounding too. It is producing heat and drying but I am concerned that something is wrong. I have an Amana LE8317W2 electric...
You will need to remove the top of your dryer and inspect the belt tensioner. If the idler roller has a bad bearing and sticks the roller will get a flat spot causing the noise you are hearing
May 08, 2010 | Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Real bad squeaking noise in dryer
There should be a access panel in the back of the dryer to get at the belt and pully. You can check the belt operation from there. If that all seems good you will need to remove the front of the dryer and check the drum supports in the front and the rear support rollors.If you hear the noise more from the front I would say the front supports are the ones thst should be replaced. And yes you can purchase a repair manual for that dryer at a parts store. Good Luck
Jul 12, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
