Question about Sony KP-57HW40 57" Rear Projection Television
Picture too big for screen - Sony KP-57HW40 57" Rear Projection Television
Can't see all the words on guide screen picture too big
Try grabbing your remote press the menu button go to picture and see if its on zoom insted of normal or stretch
Feb 20, 2012 | Vizio L32 32 in. LCD HDTV
Picture Is Too Big for Screen
Sounds like your cable box is zoomed in, I run into this a lot when running service calls. On most cable provider's remotes there is an 'aspect' button next to or around the '0'. Try that and see if it helps you out at all :)
Feb 24, 2010 | Samsung LN55B650 55 in. LCD HDTV
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Picture aspect ratio? Picture is too big for
Try VIEW MODE button on the remote or ZOOM button on the remote from cable box.
Oct 25, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a 52' big screen and the picture is shoing
Ur convergence is dead,go to ebay.com buy the convergence repair kit.Find out ur make and models,and manufactures of ur TV buy it.
All big projection DLP have this prob. one time or other every manufactures,Sony,Samsung,RCA,many others.
Aug 26, 2009 | Televison & Video
Picture goes big and small
Look for button on remote labeled size,aspect ,format or zoom. You can change the picture size to your liking. Different channels are broadcast in diffrent formats.
Apr 26, 2009 | Televison & Video
you need to go into the picture menu, and play around with the screen size options.
Jul 12, 2008 | Televison & Video
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Mar 16, 2008 | Sanyo DS27930 27" TV
Sony KP-57HW40 57" Rear Projection Television Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
