Question about LG A340 - Gray at&t Cellular Phone
LG phone doesn't ring
The volume is set at 7, vibrate on, but when a call comes in, the phone does not ring.
  • 18 Answers
SOURCE: my LG cell phone volume only goes to 7. I can not
the problem is the speaker. you must clean or replace the speaker.
Posted on Aug 11, 2009
Testimonial: "yes this was helpful. but can someone tell me how to go about cleaning the speaker?"
  • 4 Answers
SOURCE: Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
Posted on Mar 17, 2009
SOURCE: lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Posted on Apr 25, 2009
  • 8 Answers
SOURCE: When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Posted on Nov 10, 2009
  • 23 Answers
SOURCE: LG EnV3 ringer volume is LOUD even when set to LOW
I have the same issue. I know this is a roundabout solution, but I love the phone in all other ways, so I handled it like this:
I make my own ringtones with audio editing software anyway, so I just made versions of my original ringtones that were "volume-cut" by 6dB or 12 dB. Then to get these .mp3 files installed as ringtones, first I save them to the "my_sounds" directory on the micro-SD card (either via USB cable and "USB Mass Storage" mode, or by taking the card out and plugging it into my PC with an SD card adapter,)
This puts them in as "sounds" but not yet ringtones. Then, on the phone itself, I send a multimedia message of each sound to myself (i.e. to this same phone, "from me to me") Once each message is received, you will get an option to "Save as Ringtone", and once you do that, the sounds become available as ringtones.
I just use ALL of my own "volume-cut" ringtones for the different ring sounds in my phone, and it makes it quieter. Note that if you then use any "standard" ringtones, they will seem particularly loud by comparison.
Posted on Feb 13, 2010
LG flip phone won't ring, set on vibrate/ring and volume all the way up
My LG flip phone volume is all the way up. I've tried star key pound key volume keys even tried it during playing sounds and no luck. It has keypad volume but no ringtone or sound volume whatsoever. I've reset my phone and also dialed *228 but no luck yet. Any ideas?
Jan 29, 2017 | LG Cell Phones
Why wont my Lg 4G phone ring
Hey Tony,
Go to Apps then Settings then Sound.
Make sure that the Sound Profile is on Sound (not on vibrate only or on silent) and then go to Volumes and adjust ring volume to your desired settings. Case closed.
Try downloading your phone Manual of Operation from this link.
Good Luck!
JP
http://www.lg.com/us/support/manuals
Oct 18, 2015 | LG Cell Phones
I have no ringing sound on phone, i have gone to settings, ringtones & sounds, the ringer is on, vibrate is on, when i get a call it vibrates but those not ring. is there a ringing volume somewhere?
Welcome to FixYa!
Volume up your phone using the Volume Key on the left side of your phone.
  • A volume bar will appear on the screen.
  • Press the Volume Key until you reach the desired volume level.
  • Tap the ICON on the right to switch between VIBRATE and RING.
  • Make sure that it is in the RING mode.
Thank you for using FixYa.
Have a great day.
Jas247
Jun 04, 2011 | HTC 7 Mozart Cell Phone
Lg neon will not ring or vibrate
If you have made sure it's set to ring and/or vibrate and it's still not working, then turn off your phone and take out the battery. Put the battery back in and turn it on, then see if it works. This will probably fix the issue. If you haven't made sure it's set to ring/vibrate, you can do so by going to "Menu" > "Settings" > "Audio & Ringtones" > "Ringtone" > "Volume" and make sure the volume is up and not on silent. You can also quickly adjust this by the up and down arrow buttons on the side of your phone without having to go to the menu. I hope this helps :)
Apr 29, 2011 | LG Neon GT365 Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
LG env3 alarm clock vibrate
Yeah, I had that problem too. I thought my phone was broken. -_- My old phone from Verizon is like 4 years old and I JUST got my enV3. On my old phone, I'd have to set the alarm's ringtone to "no ring." But, on my enV3, "no ring" literally means NO ring, no vibration, no notification, no nothing. On the enV3, in order to set your alarm clock to vibration mode, all you have to do is make sure you "master volume" is in vibration mode, but you have to set your alarm's ringtone to something other than "no ring."
Oct 20, 2009 | LG enV3 VX9200 Cell Phone
Ring volume too low
All you need to do is goto Tools and Settings/Sound Settings/Ringer Volume
Apr 03, 2009 | LG KC910 Renoir Cell Phone
LG A340 - Gray at&t Cellular Phone Logo
106 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
