Question about Tview T102SVGR GRAY 10.2-Inch LCD Sun Visor Monitors Pair
How to get from av1 to av 2 - Tview T102SVGR GRAY 10.2-Inch LCD Sun Visor Monitors Pair
What does AV1 mean on a SAM*TRON TV mean? How do I get rid of it?
av 1 is the source input for the tv
there should be av 2, 3 4 etc and each one isa for a different input item
for example av1 is for the tv -aerial , av2 may be dvd input , av3 may be x box, av4 home theater
how to get rid of it . click on exit or ok
Sep 30, 2016 | Televison & Video
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
I have a samsung LCD TV. it shows only AV..I can not use it as AV1 AND AV2
You can select its other 2 av inputs by pressing the AV button on its remote control.
Jan 23, 2013 | Samsung P50HP 50 in. LCD TV
Toshiba back projector 43' how do i make the av
Look at what input you plugged the DVD player into. maybe AV1 or AV2
Now on your remote, or on the front of the TV, push input until it stops on the one that your DVD player is plugged into.
Aug 27, 2010 | Toshiba 43HX70 43" Rear Projection...
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Correct hookup from satilite receiver to dvd/vcr to tv
Av out from sat to AV1 on TV.
AV2 from tv to av in on dvd/vcr .
( if you can pick what av2 on the tv sends out set to send av1 out to record)
OR
AVout from sat. to AV1 on TV, AVvideo on sat to vcr/dvd.
The sat. system will act as a "play through" device so you can play vcr/dvd without changing the AV on the TV.
If you connect another lead in either option you may get a feedback loop causing audio "squeak" and video problems.
Post back to let me know if this helps.
Aug 12, 2009 | Televison & Video
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
When i record on av1 channel on dvd-sr150m there is no picture but there is a picture on av1. If record on bbc1 etc I cannot change length of recording or choose pdc. Please advise as I am ready to throw...
wow, that sounds like either the inputs are mixed in the rear . or there is 2 types of inputs av style or F connector style
av: is the audio/video cables (yellow-red/white)
F- connector: rg-6 cable or rg-59 (old school) and either one that you choose thats the way to record.
Apr 06, 2008 | Televison & Video
Tview T102SVGR GRAY 10.2-Inch LCD Sun Visor Monitors Pair Logo
15 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
