Question about Sharp CD-XP500 CD Shelf System
Turns off itself component - Sharp CD-XP500 CD Shelf System
Before I start to desolder and solder an new IR component I have a question. The green led doesn't turn on, but why does the interface module turn on when I disconnect the White and Red RCA plugs? So,...
It is probably not the IR component. It sounds more like some voltage problem between components. Can you narrow the problem down to which RCA cable and then down to the component itself? It almost sounds like the system is preventing a failure by disabling the IR component.
Mar 17, 2015 | Bose CineMate Speaker
WHY IS MY TELEVISON TURNING OFF BY ITSELF?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 18, 2014 | Symphonic Televison & Video
TV comes on and goes off by itself
There is shorted component/s at its main board. Contact any service technician. The work will not be easy for a normal user.
Gopakumar Gopalan Google
Feb 10, 2014 | RCA 20F420T 20" TV
My xbox restarts when i change to tv
Check these things:1. Is your XBOX360 using HDMI and COMPONENT CABLES?2. If you do have COMPONENT CABLE plugged in then my best bet is you're trying to play XBOX360 with 1080p which COMPONENT CABLES do not support.3. You may need to get an adapter(NOT RECOMMENDED) or just unplug COMPONENT CABLE (RECOMMENDED)lol.
Note:XBOX360 will restart itself when you switch between the two or even if you turn off and on, your TV.
My advice is to use one or the other :)
Hope this helps
TEEMAN
Nov 27, 2011 | Microsoft Xbox 360 Console
The unit seems to be turning itself off. no image
check any loose connection in PCB , re solder the component lead.
Jun 28, 2009 | Hitachi 36SDX88B TV
Tv switches on, on its own
I do not know how old your tv is, but I can tell you that if it is more than a couple of years old, the back cover needs to be taken off and blown out with clean compressed air. If your tv has quiet cooling fans on the back, they are notorious in all plasmas and lcds 32" and above for attracting dust and lint from the ambient air. This along with moisture will cause the dust, lint and moisture to settle on critical components that cause tiny static discharges between components that can produce what you described. Another thing is and this is from my own experience is that even the tiniest pest like a roach or a spider, like I said depending on the age of the tv, can cause similar problems my traversing across the components. I had an RCA that would turn on by itself and change channels by itself. All in all the one thing you can do yourself is clean it out of all dust and debri. Good luck and God bless you. Robert
Jan 08, 2009 | LG 42LC2D 42 in. LCD HDTV
RE: Sharp Aquos LCD TV, MODEL LC-37D40U Tried to switch the TV on via remote, and I hear the TV turning on, but then it automatically turns itself off again. Tried it several different ways using...
A component is shorting out, and the TV is auto turning itself off for protection. Usually it is a shorted out horizontal output transistor. Only a tech can fix this.
Nov 13, 2008 | Sharp Televison & Video
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Something wrong
A jammed or defective VCR can cause this symptom if the TV is turning itself off within about 15 seconds of turn on. Otherwise, it could be anything from a bad capacitor in the power supply to a shorted component in the High Voltage/deflection circuits. In other words, time to replace it.
Dec 18, 2006 | Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp CD-XP500 CD Shelf System Logo
16 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
