Question about Miele G2142 24 in Builtin Dishwasher
Pump still activated when door open - Miele G2142 24 in Builtin Dishwasher
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
What does f 11 indicate. The wash gets to the end of the cycle but F11 then appears and the door will not open.
F11 - Pump cannot be activated
f11 lights 1&3&4, pump/draining error
this means an open circuit pump or fauty pcb
Nov 28, 2010 | Hotpoint Aquarius WD640 Front Load...
What does the code PO mean?
Hi, PO means Pump Out (lid opened).
Po flashes when drain pump begins pumping out water from tub upon activation by the door lid having been left open for more than 10 minutes.Close door lid to stop drain pump.
Oct 04, 2010 | Whirlpool WTW6400SW Top Load Washer
Power locks have quit working, as well as keyless remote programing
the door lock system in this car is operated by a vaccume pump in the trunk. If u unplug the vaccume line leading from the pump to the car and gently blow into and **** it should activate the door locks to both locked and unlocked positions. if the locks activate then the pump is faulty if it does not activate you need to look for a vaccume leak in the lines.... there is a connector at each door post and at each door lock actuator there are 6 of them one for each door one for the trunk and one for the gas lid..
Jul 23, 2010 | 2001 Audi A4
Hi guys i own a xregseat toledo 1.9tdi se mk2
either the lock mechanism is broke or the vacumn pipe is broke that lead into the door to operate the lock but this is only on older models .That have a pump in the boot
Dec 04, 2009 | Volkswagen New Passat Cars & Trucks
Central locking device on an audi a8 year 1999
Either one of the vacuum hoses has popped off or there is a leak in the system. The system uses a vacuum pump to push/pull air through hoses connected to actuators in each door..
Have someone activate the system while you listen in the trunk for the pump, find it and see if one of the hoses has fallen off there.
Sep 10, 2009 | 2000 Audi A6
Drivers door sensor not working. Electric fuel pump is not activated when drivers door is opened. Warning for lights left on when exiting car not operational
It's the switch on the door frame that detects when your door is open. VW's are notorious for this problem. It either needs to be cleaned or replaced. Definitely try cleaning it first. It might be stuck in the "door closed" position.
Jul 20, 2009 | Volkswagen Golf Cars & Trucks
Rear door lock states its "open"
26 inch rime candy pant red
Feb 06, 2009 | 2003 Hummer H2
Dishwasher not pumping water
anti flood mechanism activated in base pan you have a leak once the anti flood is activated in puts the machine into permanent drain thats why it runs even with the door open but only runs the drain pump not the wash pump.
Mar 01, 2017 | Bosch 24 in. SGI43E05GB Built-in...
Miele G2142 24 in Builtin Dishwasher Logo
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
