Question about Bose Lifestyle 28 System
Volume level stuck .Will not change by the remote or the console.
System:Bose Lifestyle 28 Volume is at constant level.When the button is pressed on the remote or the consol, the numbers in the display change but the actual volume does not change.
  • dp2120 May 21, 2009
    My system is way out of warranty and I was hoping to save their support charges.
  • 92 Answers
BEST BET IS TO GO TO WWW.BOSE .COM AND CALL THERE 1800 NUMBER
Posted on May 21, 2009
Volume
Heyya first check out the speaker wires and then try
Dec 03, 2007 | Bose Lifestyle 28 System
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
Volume will not adjust
First, I would make sure the Mute hasn't been engaged. If that's not the problem, you might try the following: Press System on the LIFESTYLE® remote control. When you see a preview of audio features,
you can press the Enter button to move into the active list of audio options, and select "Input Levels". Once selected, the menu will run through the gamut of all the input levels. I would make sure that each of these levels is set at Normal. Other selections available are -6, -3, +3, and +6, but these are used to match sound levels of other components so when you switch from one input level to another, they are at reasonably the same sound level. navigate select
May 15, 2010 | Bose Lifestyle 28 System
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
The volume control on my Bose 38 lifestyle system will not adjust the system, with either the remote or the volume controls on on the console.
On a Bose 38, the volume will self adjust at start, and then you will be able to change volume using either radio remote, or buttons on main unit (the one with DVD).
If the unit is not responding , then there is a fault.
A fault where the Bose 38 is working (eg. you can swap from DVD to AUX on bose), but you cannot control volume (you do not see the values on main unit display) is rather unusual.
Ensure that you have correctly connected TV, receiver, or any other external device to the bose in Input, not in output from Bose.
If you have an HDTV, use the optical input on Bose, that is the only digital audio in on a Bose 38.
Check if the problem depends on connections, if it does not, let me know.
Nov 28, 2009 | Bose Lifestyle 38 System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Volume control
I had the same problem as this, but have lost my remote, so the system is know useles. Any way back to the point if you wiggle the cable around that goes in the speaker zone port then turn it off and back on then it should work :-D.
Jan 18, 2009 | Bose LIFESTYLE 28 Series III System
Lifestyle 48 locked up
Just got off phone with Bose support with this very problem during install of a VS-2 software updtae to an older LS48 system. (Bose support personnel were very helpful on phone - and walked me through procedure to solve). I presume you unplugged and replugged power supply with no resolution. In that case, unplug power supply, wait 30 seconds and while holding down the "open/close button" and the "store" button (on media center) plug the power supply back in. Continue holding until the "Bose Lifestyle" message disappears. I presume this puts the system into a diagnostic mode, as the next steps in my case were to press and hold the "erase" button while scrolling through a menu of options using the "volume up" button. I believe it was the third "volume up" press that brought me to "FLASH" on the system screen. At that point I was told to release the "erase" button and press the enter button. The system rebooted and my VS-2 install went smoothly after that.
I'd recomend calling Bose support (800-905-2138) since your lockup occured during a CD load vs a software update (just to be on the safe side) - I was talking to a live tech support person in less than 15 seconds... a pleasant surprise.
Jan 26, 2008 | Bose Lifestyle 48 System
Volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
Bose Lifestyle 28 System Logo
641 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
