Replacing the brushroll and belt usually takes care of it unless the motor is bad. Remove the belt tensioner. Only a few models had it and Dyson determined it isn't needed.
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
The belt may be worn and slipping or you may have an electrical short at a connection point. If it is the belt it is an easy fix. Here is the belt you need:
Sounds like your belt may have broken, or you have something jammed in there preventing the brush roller to spin. But most likely you're problem is a broken belt which is a simple fix that takes no time to fix
Call Dyson. if its the belt they will send you a new one. If it was purchased in the past 2 years, it has a 5 year warrenty, and they will fix it for you, but call them first!
