Question about Rainbow E series Canister Wet/Dry Vacuum
Problems with the Rainbow Aquamate II
I put together my Aquamate II attachment for my Rainbow E-series vacuum, but it wont suction the water out of the Aquamate tank to mix with the shampoo. Any suggestions?
    New Friend:
  • 27 Answers
Do you hear the pump running?
Posted on Jul 30, 2009
5 Suggested Answers
  • 41 Answers
SOURCE: Rainbow E series AquaMate II leaks around the
You have to get new O rings for it. You can find them at an Auto supply store, or hardware store. If where you first go does not have them, keep looking. You will find them.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Posted on Jun 13, 2010
  • 3 Answers
SOURCE: Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Posted on Feb 13, 2008
advacak
  • 125 Answers
SOURCE: i don't have the aquamate
any shampoo made for extractor type machines will work fine, or mix liquid laundry soap 50-50 with water (after all, you AREwashing fabric}
Posted on Dec 16, 2008
RockyNR1
  • 324 Answers
SOURCE: aquamate II NOT WORKING !!
If this is pre-owned unit that you bought - it may be clogged. If people who had it did not rinse shampoo solution out of the system after using it - shampoo becomes thick and sticky when dry and may clog the tubes. Also it may impair the pump.
Pump may also be defective. It should make a humming noise while in operation. It is hard to hear when vacuum is on so take the Rainbow with water bowl of the white AQM basin, turn on the vacuum while AquaMate is still plugged in, put your hand on the black plastic on the white AquaMater water nontainer and you should feel pump vibrating inside.
If you feel it start with filling up the white tank and bottle with warm water, turn AQM on and try rinsing it. However if water can not get through at all - it will not help.
Then take the handle apart (a bit tricky but be careful ant to break the plastic and you will get it open). See if there are no clogs there. in tubes nor the VALVE.
If no clogs fing - you will have to acces the pomp and few short tubes inside this plastic box assembled onto the water tank. to get it open you may have to break off 4 latches that hold top halve to the bottom. You can purchase one HERE. Make sure that tubes inside are not bent at the sharp angle and obstructing the flow. If you need any tubing - you can find it cheap at Home Depot (have a sample with you so you pick the right diameter).
Clean all tues inside and you possibly will have to take the pump apart to get it cleaned. If it is not working you can buy one HERE.
Stil no luck - put EVERYTHING in a plastic bag or several bags and then in a box and ship it to us - we will get it running.
Good Luck,
Rocky
Posted on Mar 28, 2009
I turned the rainbow but there wasn't any water or shampoo coming out
Genuine Rainbow Aqua Mate Ii Solution Tank Manufacturer
www.sears.com/search=genuine%20rainbow%20aqua%20mate%20...
Sears"genuine rainbow aqua mate ii solution tank manufacturer" .... Hoover FloorMate Clean Water Solution Tank for all H3000 series Models, Part (59177076).
Jan 16, 2016 | Rainbow Genuine Water Tank Cap for...
Where do I get an adapter for my rainbow shampooer
This really depends on what Rainbow you have and which Aquamate you are using. There really is not an adapter for the Aquamate. The newest aquamate out there is for the E2 type 12 black that came out in 2012.
There is a modification of this aquamate to fit older E series vacuums (comes with a cord) , but you will need to have an electrified hose made for water pick up to use. You can find that aquamate here
Rainbow AquaMate 3 carpet shampooer
GoodVac
800-775-6586
Mar 05, 2015 | Rainbow Vacuums
How does the nonelectric hose detach from the wand on rainbow e series to connect to aquamate
Rainbow E Series attachment hoses fit the wand with friction. The wand will just twist and pull out of an attachment hose. Now for use with an Aquamate, if you have the newest aquamate like here:
Rainbow AquaMate 3 carpet shampooer , the aquamate needs an electrified hose made for water pickup and a stainless steel long pipe (stainless steel so it will not rust, you can use chrome but it will rust) .
Vacuum Repair Technician
800-775-6586
GoodVac.com
Feb 17, 2015 | Rainbow Vacuums
Wont spray, no triger noise
<p>Need to know what model you have....</p>
<p>Do you have an <a href="http://www.rainvac.com/aquamate-model-am12-silver">AquaMate, Model AM12 (Silver)</a></p>
<p>or an <a href="http://www.rainvac.com/aquamate-ii">Aquamate II </a></p>
<p>or <a href="http://www.rainvac.com/aquamate-i-refurbished">Aquamate I</a>...</p>
<p>Let us know or call us to speak to a Rainbow Specialist.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Nov 04, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate II doesn't come on
The early version of the AquaMate II was very sensitive to clogging. Run very hot water through all the lines in the wash cycle to clean out soup buildup. Let us know if that fixes it.
RainVac
www.rainvac.com
800-523-0510
Jun 22, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate tank wont pump
Not sure what version you have but the early version of the AquaMate II was very sensitive to clogging. No matter the version, run very hot water through all the lines in the wash cycle to clean out soup buildup. Let us know if that fixes it.
RainVac
www.rainvac.com
800-523-0510
Jun 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I need to know how to attach the aquamate accessory to my rainbow vacuum. It's a D4 C model
You should have a non-electric hose which you want to attach to the vacuum suction, then take the long skinny hose and hook it to you kitchen faucet. You may have to unscrew the end piece from your faucet. turn on youir hot water. On the handle of the aquamate, there is a little holder. Unhook it by releasing the yellow button. Put your shampoo to the line, no need to dilute, the Aquamate will mix the right amount to the water. Now you are ready to shampoo. You can pick up water until you hear the machine stress out. That is time to change the water in the basin. It is probably best to change it before that, but don't worry, the separator keeps it out of the motor. Hope this helps fixya! Thanks, Let me know, Rene (the Vacuum Doctor)
Nov 17, 2009 | Rainbow Technologies D4 Bagless Vacuum
Dont know how to hook up the carpet cleaning part of the vacuum
You have to have the Aquamate II shampoo attachment in order to clean/shampoo your carpet. Go to the Rainbow website and you can purchase it if you don't already have one - if you do have one, this site also has simple directions on how to set up the Aquamate to shampoo your carpet.
May 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Aquamate II NOT WORKING !!
Good Luck,
Rocky
Mar 27, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E-series Aquamate II connection problem
Well I am not goinmg to call, but you can go to http://www.rainbowsystem.com/manuals/
And download the manual for your model of Rainbow.
Feb 28, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
2,014 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
