Question about Horizon Fitness Exercise & Fitness
Turns on then clicks but motor stops - Horizon Fitness Exercise & Fitness
My Motor Has stopped working and I have gone through the trouble shooting steps to fix it with no success.
if the motor turns freely and is not locked up i would look for a bad motor relay or sometimes called starter relay sounds like no power getting to motor to make it run
Jun 03, 2014 | Leica RM2255 Microtome
WFL2400AU fills with water then stops
probably just the carbon brushes on the motor the only way to get at to check is to remove the motor and they can be a arkward to get off
Mar 03, 2014 | Bosch Washing Machines
At startup the motor turns slowly about 1 1/2 revolutions, stops, chugs another 1/2 turns, then a soft click in control board and stops
59499293-16fc-4996-8de4-abe3e0c13e64.gifsee the video and lube, lube too the rollers bearing front+back too
2)see my personal TIPS for motor help. if there are voltage terminals motor, the motor can be faulty.
3) measure the output voltage control board, if there are NOT for input voltage motor, the board is faulty.
God bless you
Nov 10, 2013 | Horizon Exercise & Fitness
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
Frigidaire ltf2940fe1 error code e52 it says replace either the drive motor or speed controlboard
Hello Amy Taylor - If both the drive motor and speed control board has been replaced, then I strongly suggest contacting a professional to move forward accurately. The washer could be experiencing a wiring failure or communication error with the board, which would need further diagnosing.
Dec 01, 2012 | Frigidaire ATF6000ES Front Load Washer
Motor turns a fraction of a turn and stops. I've
With an ohmmeter between the prongs of the power plug and the switch turned on, rotate the motor and watch for a drastic change in the resistance. Theresistance should be fairky low.
IF during the rotation the resistance goes way up, there is a failure of an armature winding.
I notice it says variable speed, so the above may not work. The next plan is to bypass the speed control to see if the problem might be with the control... I suspect that is where the problem is. Bypass the control putting full voltage on the motor an see if it runs. If it does, then speed control has a problem.
Jan 27, 2010 | Dremel 1800-01 Scroll Station 18" Variable...
When I click stop the patter turns backwards a couple times?
there is sensors underneath are going or the motor is going .
Dec 21, 2007 | Technics SL-1200MK2 Turntable
Exercise & Fitness Logo
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
