Question about RCA Audio Players & Recorders
Powering up problems
Hello, I have a RCA Home Theater Model P46725sk that was made in 06-95. While watching it, it made a "snap" sound & powered off. Now it will not power back on and I can hear a very faint clicking sound when pushing the power button. I presume the power supply has went bad. Can you please provide the part number and where to obtain this part. I do want to repair this unit.Thank you.Todd K.
Kimi
  • 277 Answers
SOURCE: Not powering on
1. The power cord is not completely insered. 2. the impedance selector switch on the rear panel is not fully set to the upper or lower end - (set it when the unit is in the standby mode) other then that, you will have to call for a service.
Posted on Nov 27, 2005
MakikiChris
  • 84 Answers
SOURCE: RCA RTD258 Not working
Do you have a DVD in the player? If an incompatible region code disc was left in the player upon shutdown, it will cause your particular system to lockup. Your unit has a 1 year warranty, and you can easily obtain over the phone help from RCA by calling 580-634-0366 and have your unit?s date of purchase and model/serial number ready. The model/serial number information is on the back of your unit. During your phone call the Technician will determine if you should receive a replacement unit, and if so, will provide you all of the relavent information and a Service Request Number for your tracking convenience. Keep this SR# permanently so you can cite your history should future problems arise, also, a helpful tip is should you utilize a Passcode for your system and forget it, the Master Passcode is 9688.
Posted on Jul 31, 2007
SOURCE: Unit will not turn on.
Take the cover off and check both fan connections. I did this and it turned out to be a loose connection causing the F61 error. Also, check to see if the fans move even just a bit when you turn the unit on. If only one moves then you may have a burnt fan, if neither move you have a major problem. If they both move continue checking connections, loose solders etc. If all else fails, but a new one.
Posted on Sep 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA Home theater Television P46725SK
Is there a pattern to the blinking? This may be blinking an error code that is indicating the nature of the problem. count how many times it blinks, and wether you hear any sounds such as clicking.
Posted on Apr 09, 2008
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
How do i program rca home theater
How to Setup a RCA DVD Home Theatre System RTD325W ...
? 10:31
https://www.youtube.com/watch?v=20dRIj8KWPU
Jan 28, 2012 - Uploaded by TheHandofOdd
Just how to setup and get the optical cable working for those who need help.
RCA Home Theater System Set Up - YouTube
? 5:37
https://www.youtube.com/watch?v=j0UhnbrjJto
Sep 14, 2012 - Uploaded by gangstafly5000
The RCA hooked up to 43' plasma Samsung. ... RCA Home Theater System Set Up. gangstafly5000 ...
RCA 5.1 Surround Sound 1000 Watt HOME THEATER ...
? 13:06
https://www.youtube.com/watch?v=1xfEmkwCwyA
Oct 18, 2014 - Uploaded by bigtruckseriesreview .
I bought recently rca system home theater and makes strong fan.... +Aiden woodruff Change he settings to surround, and make sure all of the ...
How to Set Up an RCA Home
Jan 13, 2016 | RCA Televison & Video
Rca rt2781h loosing sound
Hi. replace the hdmi cable with a new one..
Aug 04, 2013 | Audio Players & Recorders
Protector/push power comes on when powering up sony home theater. checked wires for shorts and cleaned air vent . what else can I do
Usually means there is a short in the amp section. Depending on the model, this can only be fixed by replacing the amp ic or the amp pcb.
Jan 09, 2013 | Audio Players & Recorders
Where can I purchase a mother board for the RCA Home Theater TV model type P46725SK?
Try website like Tvrepairworld.com have many DLP RCA tvs refurbishes boards parts,should have the mother board too.
Jan 13, 2011 | RCA P46924 46" Rear Projection Television
Purchased an rca home theater pkg in 1994. recently moved to new location, now amp display is stuck on "wait". cd player appears to be working, but no sound. 135 watt hi-fi audio amplifier...
There are some worn out capacitors in the power supply. Most can be visually detected by looking at the tops of the round metal cans. If they are not flat on top, then it needs to be replaced.
Dec 21, 2010 | RCA Audio Players & Recorders
Can't get the tv to play through the home theater
No they all are compatible with eachother no matter what brand tv,surrround sound. It is all in the hook up & without you stating how you have it hooked up,no way to tell because one siimple connection is all you r missing. You have it most way there if sound is ok on dvd.If you explain how you have it hooked up i can surley help you!!
Jan 23, 2009 | RCA L32HD31 32 in. LCD HDTV
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Dec 23, 2008 | Sony BRAVIA® DAV-HDX576WF Theater System...
RCA Home theater Television P46725SK will not cut on.Power button blinks when trying.
Apr 09, 2008 | Televison & Video
77 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
