Question about Nordic Track Walking Belt For The Nordictrack Powertread 6.0 Treadmill
Can not replace belt on Nordictrack powertread 6.0
Sides do not come off
I have a Nordictrack T9.2 and the belt is slipping to one side when switched on ...I have tried adjustment with the Alan key provided but it has not made a difference
There is a procedure for adjusting the treadmill belt. Almost all the treadmill follows the same procedure. If you wish to know how to adjust the treadmill belt properly then check the below added link. Even after that if you face the same problem then you have replace the running belt of your treadmill.
http://electro-medical.blogspot.com/
Sep 25, 2016 | NordicTrack Exercise & Fitness
I have a nordictrack a2350. The belt runs fine until you step on it. How do I fix this?
the walking belt may be loose. adjustment screws are at the back of the walking belt. one on either side
Mar 30, 2015 | NordicTrack Exercise & Fitness
Squeaky sound
LUBE inmedIATELY the deck belt +rollers bearings too. If the problem persist time to replace the complete deck belt board.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack Powertread 5.5...
I was cleaning a powertrex treadmill yesterday and it was working fine . tried it this morning and a fault E06 has came up . took cover of and there has been a few drops of water that has got into parts of...
try to use a small gun for dryer and pass for electronic board very carefully or let to dry by itself by 24 hours or add some lamps by over the electronics boards.. And try again.
If the problem persist, you must call some elect tech.to due that will be some condensation and electronic short can be ocurr.
God bless you
Dec 11, 2012 | Treadmill Doctor Nordictrack Powertread...
I HAVE POWERTREK STRIDER IS NOT WORKING WHAT WILL I DO
see the next causes and remedy and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 13, 2012 | Treadmill Doctor Nordictrack Powertread...
Our Nordictrack Track Exp100S has problems. The belt rubs on the left hand side (my left as I'm walking) at the back of the treadmill. What should I do?
Inspect the rear plastic end cap. It is the plastic part at the back of the machine. The adjustment screws can be found there. These end caps disintegrate after time and break. You will see the discoloured plastic where the damage has occurred. If this is the case, the end cap must be replaced and belt readjusted.
Jan 04, 2011 | Treadmill Doctor Nordictrack Track...
Belt will not stay tight.
Is it slipping side-to-side or front-to-back? If side to side, you can stop this by adjusting the two allen bolts on the bottom fronts sides of the treadmill. If it is front to front, and your treadmill is more than a few years old, the belt is probably stretched and needs replacing.
You can get a quote for a new belt at treadmill parts
Dec 19, 2010 | Nordic Track NordicTrack A2750 PRO...
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
Nov 07, 2010 | Nordic Track NordicTrack Treadmill, A2550
Walking belt on NordicTrack C1900 is to loose, how do I tighten it? When walking on it when u get to level 4 it just about throws u
Tighten the rear roller bolts evenly with the unit off. The correct tension is when you firmly lift up on the right and left edges in the middle of the walking belt and get 2-3 inches gap above the walking board. If one side is looser than the other, the walking belt may wander sideways. Turn the rear roller screw on the side that it shifted to in a clockwise manner(1/2 turn at a time). Test on a low speed and adjust as needed. (you may manually recenter the walking belt with your foot if it shifted too far to one side and is rubbing on the plastic edges.) You likely have a worn motor belt that needs changing or even a pulley on the front roller that is slipping and needs replacing. They all cause slippage.
Sep 30, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track Walking Belt For The Nordictrack Powertread 6.0 Treadmill Logo
19 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
