Question about Crafts & Hobbies
Dw734 planer problem
Feed chain skips
    Genius:
  • 1,406 Answers
You have badly worn-out sprockets, or you have an idler sprocket that's missing or very badly out of adjustment. It's possible that your chain has stretched beyond recovery, and needs to be replaced.
Posted on Jul 29, 2014
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: how do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Posted on Jul 17, 2010
  • 71 Answers
SOURCE: Need owners manual for Delta DW734 thickness
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
Posted on Nov 18, 2010
Blades wont lower
DeWALT DW734 Type 1 12 1 2 inch Planer Parts
Clean the machine inside usually there is a line or square wood cross and
use a dust extractor with an induction motor, high enough capacity
Dec 01, 2015 | Dewalt DW734 15 Amp 12-1/2-Inch Benchtop...
Chain feed skips
chuck or worn chain cog
Jan 01, 2014 | Dewalt Planer (DW734)
Change the belt on a dewalt 733 planer
Here is a link to a site I am a member of, Lumberjocks.com. The link is for a discussion on how to replaced the belt on your planer!
Good Luck!
http://lumberjocks.com/topics/10176
Oct 03, 2013 | Dewalt Planer (DW734)
Carrage won't hold thickness
Either it is not really locked in place, you have a loose nut on the other end of the adjuster or a bad bearing.
Sep 05, 2012 | Dewalt Planer (DW734)
Dw734 planer
More than likely the screw threads are gummed up. Make sure the locking mechanism is up and lower the carriage. Clean the screw threads, spray with WD40 and wipe off the excess. I had the same problem because rarely raised the carriage above 2". Hope this helps!
Jun 30, 2012 | Dewalt Planer (DW734)
The self-feed slips on my Dw 734 Planer.
I have had the same problem with my planer since it was new. I hate this planer. The way I fixed it was to pull the feed rollers off and put one washer in the hole the pressure springs are on the rollers. I also put about a 1/32 washer under the hold down plate for the roller. It allows the rollers to put more pressure on the wood. Now it works perfect. If it sounds complicated, it will all come together when you take it apart. You take the bottom off to do all this. Trust me it works and is worth the trouble to do it.
Oct 25, 2011 | Dewalt Planer (DW734)
Owners manual for a dewalt planer
The Instruction Manual for the Dewalt DW734 Heavy-Duty 12-1/2" Thickness Planer can be downloaded from this link:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DW734#
Scroll down in the list of downloads to Instruction Manual and select the icon under PRINT DOCS.
May 15, 2011 | Dewalt DW734 Heavy Duty 12 12" thickness...
My Makita 2012 planer 'skips' making a 'machine gun' sound and the wood won't feed through. I think it's the 'plane bearings', but I'm not sure. Does this sound right?
Have you cleaned your rollers? I must admit, I'm having this problem with my 2012NB, I HAVE cleaned the rollers (with ethanol), and have taken the side covers off, and the drive chain and gears look just fine, as does the primary drive belt. I ran the planer with the covers off, and although the gears and belt seem fine, the planer still skips (or slips). I think probably your blade is dull, creating drag (I replaced mine not long ago, but have been planing a lot of rough lumber). I still haven't gotten to the bottom of it, but I think the rollers are slipping, I just don't know why yet.
Feb 02, 2011 | Makita 2012NB Electric Planers
I need a operator and service manual for a Dewalt 734 planer. Where do I get one?
Here are all the manuals for your planer:
User and parts,
http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
See the right side of the page to download the pdf files. You will have to click the pront doc column where the pdf icons are located. Once you click the pdf icon it will give you the option to either save it or open it. The instruction manual is 9.16 mb
Thanks for choosing FixYa,
Kelly
Dec 28, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
Need owners manual for Delta DW734 thickness planer
Nov 18, 2010 | Dewalt Planer (DW734)
Crafts & Hobbies Logo
171 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
