Question about Princeton Digital VL1919 19" Monitor
At start up it displays a message "frequency out of range" please change the display mode to 1280 x 1024 with 60Hz, any idea why its doing this and how to solve this issue so i can log back on to wind
My Princeton monitor all of a sudden displays the message "frequency out of range" at start up.No other display message and I'm not able to log on to windows this way anymore. Any idea why it all of a sudden displays such a message? Thanks
  • 8 more comments
  • reinerof94 May 21, 2009
    its a princeton VL1919 LCD connected with a vga cable to my desktop
    Hi benwabnick, I just did that and it worked. However, I've disconnected the vga cable from the monitor before and it worked as well for a little while. What should that solution do?
    thanx
    Nick
    frankzjm it did this with the onboard vga addapter that's why I bought a video card which can only be a agp but it does the same still
    benwabnick I did that already for the geforce 7300 gt
    do u think the monitor needs its own driver update maybe?
    MrDallasIT thanx MrDallasIT...I'll try that
    I don't think its a video driver issue since it did the same thing without a video card before...it may need a monitor driver which is probably hard to find for the princeton brand...
    thanx guys for all the support...by just disconnecting then reconnecting vga cord the monitor is working now...maybe the vga cord was kinda lose, who knows...the Herz is and always was at 60Hz...again, thanx to all of u for the support
    Nick
  • Frank Zhang
    Frank Zhang May 11, 2010
    your destop video out from AGP card or onboard VGA port?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Turn off the computer and the monitor. Then turn on the monitor and then after 3 seconds, turn on the computer and see if it boot up into windows properly.
  • Frank Zhang
    whats host connect to the moniter? brand model?
  • 191 Answers
Ok you may do soluton #1 make monitor show windows start. then enter windows-->enter control panel --> display--> setting --> monitor -->
choose the refrash frequency to lower stage (at least 60 Hz)
until no message pop on the monitor.
heop help you fix it.
Posted on May 21, 2009
  • 1 more comment
  • Frank Zhang
    Frank Zhang May 21, 2009
    add: please do solution #3. make monitor show windows.
    enter control panel--> display --> setting --> advance --> monitor -->......
  • Frank Zhang
    Summary those solutions tel you know why you met this problem:
    1) host and device has initial sequence, that should be:
    turn on sequence: device (monitor) turn on --> host( your PC) turn on, turn off sequence: device turn off --> host turn off,
    if any hardware operating aganst this sequence should be cause some initial problem, like yours
    2) your PC has two VGA output (onboard and AGP card) there are different resolutions and might be different refresh frequency, also the monitor has recognize and memory first connected resolution and refresh Frequency setting from PC VGA port. if you change your VGA port but do not according power on/off sequence, the monitor still memory previous resolution or refresh freqency setting. so that the error pop message shold be occured. but it is never cause from the VGA cable it self.
    this is a computer theory, just give you a sense.
  • Frank Zhang
    Frank Zhang May 22, 2009
    please take a rating to our solution let our know how much helped you thanks! see you again.
  • 2,404 Answers
What I had you do was to make sure your computer can recognize your monitor properly. The only other thing you may want to do is update your video drivers.
  • Ben Wabnick
    Ben Wabnick May 21, 2009
    update the driver to if you can. I don't think its a video card problem.
  • Ben Wabnick
    cool, glad it worked don't forget to rate me please Nick, when you get the chance.
    Ben
  • 91 Answers
Sounds like you you have a video driver issues. Disconnect your monitor while your PC is still on, and then reconnect it, and perform a reboot...
WHEN STARTING WINDOWS PRESS F8 KEY AND START PC IN SAFE MODE.. THEN CHANGE DISPLAY MODE TO 800BY 600 RESOLUTION
Jun 11, 2013 | E-Machines eMachines Monitor E15T4
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
Screen says "OUT OF RANGE H:27.8K V: 62.0
That's the monitor telling you it's getting a signal it can't handle. The H and V values are the horizontal and vertical frequencies that control the display. They change depending on your computer's video card settings. The monitor can be damaged if run at frequencies outside its safe range, and it displays the message you're seeing to protect itself.
Start your computer. When the manufacturer's splash screen (logo screen) comes on, press the F8 several times. This will get you to a startup options menu. Select "Start in VGA mode" from the list. Windows will start up then with settings every monitor can handle, and you'll be able to see again.
You might have a game or other graphics application that changes video settings to something the monitor can't handle. If this is the case, and those settings are required, you'll need to invest in a monitor with a greater settings range.
Feb 04, 2010 | Hyundai ImageQuest QV770 17 in.CRT...
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
Stars then says frequency out of range
start your computer in safe mode. Here's how to do it.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
once the computer is in safe mode, click on start > run and type desk.cpl. go to settings and then screen resolution. drag the slider to the left for the lowest setting. then press apply then ok. and restart your PC.
Nov 11, 2009 | Computers & Internet
"out of frequency range" message nothing works
Try booting to the ENABLE VGA mode off the F8 menu if you can get to the desktop and then you can go to display properties and see if you can reset the resolution to normal. If no go, try updating the video driver
Oct 02, 2009 | HP Compaq FS 7550 17 in.CRT Conventional...
Monitor Problem
That is because your computer is trying to display a picture at a higher resolution than the monitor can handle
EG. if your monitor was only capable of lets say 800 x 600 and you decided to try force it to display 1680 x 1260 your monitor would do one of three things
try but die doing so
switch itself to sleep or standby mode
scream at you that its "OUT OF RANGE"
The H & V numbers are horizontal and vertical frequencies sometimes it is possible to use the monitors own OSD to change these but please check in the monitor manual before you do so.
Your best bet is to start your computer in safe mode and re-set the resolution to something a little more in the range of the monitor and then try re-boot.
If this information was useful then please click below
Aug 17, 2009 | Princeton Digital VL1916 19" LCD Monitor
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
OUT OF RANGE on monitor screen
you have to change frequency of monitor to work smoothly form display property.
Out of Range is frequency is not matching
To solve this, wwhile booting Press F8 to get advanced boot menu from that select "Enable VGA mode"
change the display properties
right click on desktop - Select properties - Settings - Advanced (from bottom) - goto monitor tab - change the frequecny to default. and restart the system normal mode
May 25, 2008 | XFX GeForce FX 5200 Graphic Card
Princeton Digital VL1919 19" Monitor Logo
649 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Sunday Ojelabi
Sunday Ojelabi
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
