Question about Lexmark C510 Laser Printer
Lexmark pro 905 prints color but not black, replaced printhead but did not fix problem
Stopped printing black, cleaned printhead then replaced printhead, still have same problem
agent1463
SOURCE: Colored Ink problem
Good day sir, My Lexmark z35 color printer doesnt work. I already tried to use the printer settings properly but still failed to print the color ink. Only black ink in printer is printing. Im still hoping that you have any solution for this. pls.. help. thanks!
Posted on Jun 16, 2007
  • 2072 Answers
SOURCE: Lexmark X1185 won't Print Color
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Posted on Feb 22, 2008
  • 66 Answers
SOURCE: print head replacement lexmark t632
Hi Kmccue,
The Lexmark T632 is a laser printer. It does not have a printhead. Perhaps it is the toner cartridge you are talking about. Pull the cover open in the front and pull the cartridge out.
Rgds
S88
Posted on Dec 19, 2008
  • 81 Answers
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Posted on Jan 03, 2009
I installed a new black cartridge, however it does not print on the test page only the blue marks print, I have removed the strip of tape and soaked the print head in hot water but it still does not print, when I dab a cloth toit the black ink bleeds on the cloth so can you help me resolve this?
Posted on Dec 19, 2009
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
I bought and replaced the black and yellow printhead today. It printed some colored pages. Then when I began to print this evening a colored page. It stopped in the middle of printing and the printer...
please take your print head and get it tested or get it replaced, or you could take your printer to a local HP service centre and get it checked, rather than trying to fix it yourself you mite damage the sensors for the print head.
Sep 13, 2011 | HP Officejet Pro L7680 All-In-One Printer
Lexmark Pro 905. How do you print a document in black only. I know how to make copies in black but I can't figure out how to print in black.
Go into the color control settings and pick Grayscale or B&W; if you pick grayscale be sure to test print and adjust print density so black doesn't look medium gray and the rest illegibly ephemeral.
Aug 06, 2011 | Office Equipment & Supplies
My Lexmark prevail pro 705 has stopped printing anything colour even after i have replaced all the cartridges??
This article on How to Troubleshoot the Vizix Ink Technology will help fix print quality problems on your printer. To run the Deep Clean Printhead function on your printer -> on the printer operator panel, press Setup -> Maintenance -> select Deep Clean Printhead. Your printer will then print the test page. Hope this helps. Thanks.
Jan 11, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Alainment problem, replaced the black cart. and now I can't the colors to alian properly. when doing the alianment test the 2nd black and blue line print a solid black but the blue is fussly..when printing...
This could be due to a problem with the printhead or the cartridges try doing a clean printhead by going to the Lexmark productivity studio or Center. You can clean the contacts of the cartridges by following this instructions. http://bit.ly/9UGXvc
Feb 23, 2010 | Lexmark X5470 All-In-One InkJet Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
Lexmark C510 Laser Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
