Question about RCA Televison & Video
How to hook up dvd player to tv
How do you hook up a dvd player to this set
  • 192 Answers
You need an RF modulator to convert the A/V output (RCA jacks) of the DVD player into a Coaxial cable you can plug into the back of your TV. I'm including a link to one at radioshack.com. This one costs $27.49. You might be able to find a cheaper one at a discount store. You can also use an old VCR if you have one to do this conversion but the connections get a little bit tricky. Plug the A/V outputs of the DVD player into the A/V inputs of the VCR. You'll have to set up the VCR so it knows to use the A/V inputs. Some VCRs have and AUX setting for this. Then connect a coaxial cable from the VCR output to the TV input. You'll have to setup the VCR to send it output to a specific TV channel, usually channel 3 or 4. Then you'll have to set your TV to that channel.
http://www.radioshack.com/product/index.jsp?productId=2103095
Posted on May 21, 2009
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I have a converter box and a dvd player hooked up to an older sanyo tv. How do I get my pic to show from the dvd to the tv.
The DVD most likely has to be connected to a audio/video input on the set--once hooked you have to be able to switch the TV set to that input with either a input button on the set or with the original remote.
May 27, 2012 | Televison & Video
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
How do u hook up the dvd player and dish network to your tv
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
DISH Network Customer Service
Dec 10, 2010 | Sanyo DWM400 DVD Player
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
Need to hook up a TV,VCR-DVD player,and CD player
Progressive scan video output would be available on Component Video terminals of dvd player so set connections between TV and dvd player via Component Video cable.
Please intimate model and brand of product that you need instruction manual.
Thanks.
Aug 31, 2009 | Sanyo Cinematic Progressive Scan DVD...
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Televison & Video Logo
376 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
