Rainsoft Q2 error 1 - 11 , what does that mean?
Rainsoft Q2 water softener is not working, error 1 - 11 on display. New battery and fuse good , what does that mean? Thx.
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I have a Kenmore Refrigerator:
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Posted on Sep 27, 2010
SOURCE: One of the gears on my intermatic timer broke.
You might try contacting Intermatic directly:
http://www.intermatic.com/customer%20service.aspx
As a serviceman myself, I can tell you that selling parts for stuff ends up with serviceman spending time on the phone helping to repair the thing for free. Not just that, but servicemen have to salvage parts and know which parts to salvage, and then inventory the parts, and remember where all that dang stuff is ... and with overhead, and cost of labor and trucks, the part costs the same as a service call. So hire the guy or buy a new one.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 05, 2011
What does E-1 error indicate?
Depends on the make and model of your water softener.
Guessing you have a brand manufactured by Eco Water (Sears Kenmore, GE, etc). If so, the E-1 indicates that either the motor or wiring harness has gone bad. One way you can test this is to unplug the softener, wait a short period of time than plug it back in. If you hear a clicking or snapping type of sound, the motor is shot. If so, most likely cause is the seals and O-rings in the valve have worn out and causing the unit to bind up. You would need to replace the valve's O-rings (they make a complete kit just for this) and the motor. I would also check the rotor for any damage or excessive wear.
If you have a Culligan unit, an E-1 code means that the timer board is bad. Unplug the softener for a few minutes and when you plug it back in, it should reset. If it does not reset, it means you need a new circuit board.
Nov 30, 2015 | Water Dispensing & Filtration
Need help concerning a Kenmore 384200 water softner
OK this may sound to simple. First check make sure that the softener has a good steady power supply. Check make sure it's plugged in. Then check the electric supply box...the fuse box and see if you may have tripped a breaker or a fuse. The softener should have a red or green light if you have power. Red light display means that the softener is in error protect mode a lot of times your timer needs to be reset like extended period of loss of power. ..but usually provided you have power without any outstanding issues. ..just unplug unit for 5 minutes the repower it up by simply plugging it back in
Jun 17, 2014 | managemylife.com
Rainsoft water softener
In a Computer? Sweet!
Feb 16, 2013 | Computers & Internet
Alesis Quadraverb Q2. When I turn on Alesis Q2 the programs 1-100 preset are working but when I turn on programs 200-300 user It does not work. There is only "bad program" characters on display.
The Problem is a dead battery which is soldered to the circuit board inside the unit. It's a Panasonic BR-2325-1HC, but really you can replace it with any similar 3V battery.
Here's how I fixed mine.
http://andrewapeterson.com/2013/08/fix-alesis-q2-first-made-strange-sounds-then-bad-program-issue-quadraverb-2-battery/
Feb 07, 2013 | Music
One of the gears on my intermatic timer broke. I've been trying to find a supplier to purchase the gear from,but have been unable to.It's a Rainsoft water softener.I contacted the local Rainsoft dealer and...
Dec 11, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have a Kenmore Refrigerator: Model Number 106.50254001, Purchased 1-24-2001. It has a water and ice dispenser on the front. I purchased a Rainsoft Water Softening system, with a Reverse Osmosis System...
Sep 27, 2010 | Kenmore Refrigerators
Have an rainsoft Q10 classic apollo softner that does not draw brine. Ran a wire thru the brine injecter tube and it appeared to be clear of obstruction. Drained tri-guard glass did startcycle and redrew...
You most likely have a slight leak in the brine line. This is the most common failure on a water softener. A slight leak will allow air to enter during brine draw, breaking the vacuum. it doesn't take much of leak, in fact it can be small enough that water does not leak out during brine refill but it will not draw brine. Check the compression fittings at the brine tank and the softener valve. disassemble the connection, cut back the tubing and reconnect. Other things to look for are low water pressure, the unit requires 25 psi minimum during regeneration. Also make sure the drain line is not restricted and the maximum head on the drain is 4' over the softener.
Mar 16, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener is inoperative and is displaying E1
Usually, an E1 error code means the circuit board is bad. Try unplugging the unit for 5 minutes. Upon plugging it back in, if it does not reset itself, that means you need a new board. It is really easy to replace ( just a few wires) and will cost around $160.
Jan 05, 2010 | Culligan Sediment Water Filter
Water in water out ??
rainsoft.com is the site. water usaully enters rear, depending on model
Feb 26, 2009 | Plumbing
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
