Question about Dirt Devil M084600 Dynamite Bagless Upright Vacuum
Not sucking from the bottom
My vacuum is not sucking from the bottom. It sucks using the other tools, but not from the brush bottom. What can be done?
  • 55 Answers
I have a Dirt Devil upright. We have 4 women with long hair living and visiting us. I noticed the unit not sucking very well. I turned it upside down and found hair had wrapped itself around the belt driven brush--big-big-time! I disasembeled the brush-cleaned and cut the hair free. I noticed the hepa filter had not been replaced so I replaced it. While the rotor is removed look at the suction inlet- something might have lodged in to it.I really feel that the problem is in the lower part of the unit.
Posted on Jan 02, 2014
  • Dirt Devil Master
  • 18,392 Answers
3 Suggested Answers
grandadfixer
  • 99 Answers
SOURCE: Brushes at bottom of vacuum
Blockage somewear
Posted on Oct 11, 2008
  • 58 Answers
SOURCE: dirt devil mvp not sucking
These Red Devil vacuums (like the similar Hoover uprights from the 1970's) rely on the sealed rigid bag case to pull the air through the bag before it reaches the vacuum motor. Any air that leaks into the case without passing through the bag decreases the available useful suction.
As a side effect, the motor runs slower when the case isn't sealed because ironically there's more air coming in for the vacuum motor to move and its working harder. The vacuum motor spins fastest when the vacuum is sealed up and the hose is blocked and no air passes through the machine.
Posted on Jul 28, 2012
After my son vacuumed up maybe a lego theDiamond G Kirby started sparking from inside housing. We took brush and checked for any loose items and found none. Any ideas and can I diy?
Sucking up a Lego or similar item normally should not have done any damage to the motor. It may stop the brush roll which may burn the belt if the belt is tight. If the item got sucked into the fan it may have broken or cracked it which could seize the motor. Remove the brush roll assembly, spin the motor shaft while you inspect the fan. Fan replacement is best to be done by an experienced technician.
Jan 24, 2017 | Kirby Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Vacuum not sucking from the brush bottom
Probably clogged at the intake. remove rug plate and check intake. Broken belt is other possibility. #5 belt. This a ver basic vacuum, so not much to go wrong.
Jan 02, 2014 | Dirt Devil M084600 Dynamite Bagless...
I have a Hoover Turbopower 5100 . I have power, and my spinner turns. But I have no suckson power. I look for and blockage. couldn't find a thing. what's wrong?
Same problem here, after 1 month of use, it just wont suck on the bottom side, the hose works correctly with the accessories, but the bottom wont suck, the brush works fine by the way. I removed the hood checked the inside, looked for clogs and nothing.
Oct 01, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Floor level brush stopped rotating after it caught
Look at the bottom and check a thread of carpet isn't wrapped around the brush, if so try pulling it off or carefully cutting it off. You'll probably see a collection of fluff etc above the brush that's stopping it from sucking up, pull this out, or it just may be that cause the brush isn't working its not picking up.
If this helps please rate me
Jun 20, 2010 | Bissell 6594 PowerForce Bagless Upright...
My Oreck XL has quit sucking. The brush turns but
Same problem here with XL9100. Bag would not expand implying no suction. Motor ran and brushes turned. Easy disassembly using common tools found that a plastic bag had been sucked up and caused a blockage prior to the impeller. Cleaned up, reassembled, and everything worked fine after that.
Nov 05, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Doesn't suck
you need too change the belt on the bottom where the brush is take off bottom cover and underneath is the belt if its broke replace it
Dec 22, 2007 | Kenmore 35912 / 35913 Progressive Upright...
My dirt devil vacuum won't suck up anything and its brand new!!
Take the vac bag off and turn on the vac , it should blow air out, if not unclogg the hose where the bag connects, also when you check the roller and belt, unclog the flex hose(located inside base near roller assembly) that sucks up the dirt. As long as the motor works fine the rest is just maint.
Mar 30, 2007 | Dirt Devil M085805 Upright Vacuum
Dirt Devil M084600 Dynamite Bagless Upright Vacuum Logo
191 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
