Question about Gateway MD2614u Notebook
How do i replace my LCD inverter on my MD2614u gateway laptop
I need to replace the LCD inverter on my laptop
aberry9036
  • 49 Answers
SOURCE: Unable to remove Gateway m680 Laptop LCD Bezel
I would try just using a little bit more force (not too much!) the bezel will have clips around it to keep it in place along with the screws under the rubber protectors. Also make sure that the bezel doesn't hook in to the hinge cover in any way, as this will prevent it from coming off properly. If it does then pop the hinge covers off before continuing.
Posted on Aug 04, 2009
leecom72
  • 4806 Answers
SOURCE: How do I replace the LCD inverter in a Gateway
Remove the screen bezel (plastic screen surround), this will reveal the whole screen. At the bottom of the screen you will see an elongated piece of circuit board with wires coming from either end covered by frosted plastic.
That is the inverter, to remove it gently pull the plugs from each end and remove the screw from the middle and pull the board away and replace it.
If you have not got a replacement yet look at the inverter for a copper coil, if you re-solder the solder points around the coil you may find it works again as components that suffer from extreme heat the solder joints dry causing bad connections, re-floating the solder solves the problem in 90% of cases.
Good luck.
Posted on Aug 06, 2009
SOURCE: have a gateway md2614u laptop. need to change the
I searched gateway's website but they're pretty tight lipped about their service guides. I did find this link to some pdf files, even though it's not your exact model, you might find some useful info there. Hope this helps and good luck. If I 'fixed ya' please rate me.Thanks.-jmattes ( just copy and paste the link into your browser) http://tim.id.au/laptops/gateway/
Posted on Oct 26, 2009
GodBlessU
  • 3513 Answers
SOURCE: How do i replace the screen on my gateway model
Hi
Please chek the bellow links for your answer..:-
http://www.insidemylaptop.com/remove-lcd-screen-from-gateway-mt6704-model-ma7/
http://www.insidemylaptop.com/replace-broken-lcd-screen-gateway-m-series-laptop/
Thanks for contacting fixya.com
Posted on Nov 13, 2009
  • 561 Answers
SOURCE: Coil Part Number for Gateway MT3707 Inverter Board
Hi
Thnak you for your query
You will have to replace the WHOLE inverter board, not just part of it
The inverter is responsible for taking 12V supply and converting the power to a higher volatage to allow the screen to light up
I would suggest that you book the laptop into a reputable PC shop to complete the repair
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Posted on Feb 19, 2010
Gateway md2614u shut down
I would remove the heatsink and fan, clean the processor surfaces with methylated spirit or isopropanol, use new heatsink compound and that should fix your issue. Yes yes, heatsink pipe should get hot!
Nov 17, 2013 | Gateway MD2614u Notebook
How to replace a video cable
In a Gateway M-7351u Notebook PC?
1) http://www.insidemylaptop.com/replace-broken-lcd-screen-gateway-m-series-laptop/
2) http://www.insidemylaptop.com/replace-keyboard-gateway-m-series-notebook/
Motherboard side of video cable, should be under the Switch Cover, (LED indicators, Power On button, speakers, etc), or under the Keyboard close to the Switch Cover.
Don't forget to remove ALL power. Remove the AC adapter (Charger), and Battery. (Use CARE. Wires going to Switch Cover. Do not cut them by accident, or pull on them when removing Switch Cover )
http://www.ebay.com/itm/GATEWAY-MC7310U-MD2614U-LCD-VIDEO-CABLE-DD0AJ2LC000-/390069940144
Regards,
joecoolvette
Oct 24, 2012 | Gateway M-7351u Notebook
I replaced the entire monitor for my md2614u laptop and still a dim visual but still dark, what should i do now? could it be a short in the wire?
Hi, First make sure your tape connections are correct, if everything is okay then you have/need, a new video card. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 03, 2017 | Gateway MD2614u Notebook
How to replace a battery for a Gateway MD2614u Laptop.
You can buy one here http://www.amazon.com/Replacement-Gateway-MD2614U-Laptop-Battery/dp/B003W1UARM
That's not a bad price.. an old Toshiba Battery actually cost me $120 for a replacement.
Mar 24, 2011 | Computers & Internet
Laptop will not power on. I push power and all lights power up then sounds like it will power up then fizzles out and doesn't turn on
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
This place will show you what the inverter board looks like: http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
Mar 30, 2010 | Gateway MD2614u Notebook
I have a gateway MD2614u and I need to replace screen, but find no screws to get to it. could you please help? Thank you ANYONE
If you do not know "HOW" to do it -- then STOP.
Take the computer and the new screen to a qualified technician, and hire them, about $60 for one hour labour, to do it safely and correctly.
Jan 13, 2010 | Gateway MD2614u Notebook
Gateway MD2614u Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
