Question about NEC 1740CX-BK (black) LCD Monitor
Osd will not go away
After powering up my NEC 1740cx monitor, the on screen display should stay on for about 2 seconds and disappear, but it is staying on indefinitely. i must push the select button to make it go away. what could be causing this?
  • walilkoa May 21, 2009
    the problem has nothing to do with my ability to use the menu. the poweron popup should only tell me the input path then turn off almost instantly. i reset the monitor to factory settings and tried turning it off and on again, but the input notifier still stays on indefinitely. i'm able to use all other functions of the osd and monitor just fine.
  • 91 Answers
Make sure you completely exit out out of your display properties..
Posted on May 21, 2009
Need OSD Lock out removed permently Please
have you tried the following steps:
  • Press and hold the "Power" key on your monitor to turn it on. Press the "Menu" button for 15 to 20 seconds to cancel the OSD lockout message.
  • Press the "Power" button on your monitor for several seconds until you see the OSD lockout message disappear. Unplug and re-plug your monitor power cable back into the outlet if the OSD lockout message is still displayed.
  • Turn your computer's monitor off. Press the "Menu" button for 15 to 20 seconds and power your monitor back on.
  • Read more : http://www.ehow.com/how_10015851_fix-osd-lockouts.html
    Apr 09, 2015 | Microsoft Windows 7 Home Premium 64BIT...
    Monitor display says OSD Lockout /no signal input how to fix this?
    This document pertains to LCD monitors .
    One of the following messages appears on the screen (over the items being displayed).
    OSD Lockout
    OSD Lock-out
    ... or similar message.
    This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
    NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
    To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
    Aug 31, 2013 | Dell Computers & Internet
    My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
    The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
    I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
    1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
    2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
    3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
    4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
    5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
    Mar 01, 2011 | HP 1730 LCD Monitor
    An OSD message appears in a box that covers much of the monitor screen. The mouse pointer disappears behind the box whenever I try to sweep into it. The box will not go away (except intermittantly)...
    OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
    If you still have problems, click on this link for further instructions :-
    Dec 29, 2010 | HP Computers & Internet
    The brightness icon stays on my screen
    The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
    * If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
    * If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
    May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
    Oct 31, 2010 | Office Equipment & Supplies
    When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
    I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
    I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
    Locking OSD settings
    When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
    Special messages display on the monitor screen for the following monitor conditions:
    • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
      • For the w1858 monitor: 1366 x 768 @ 60 Hz.
      • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
    • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
    • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
    • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
    • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
    • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
    May 13, 2010 | Computers & Internet
    Stupid padlock/main menu keeps opening and closing DELLe152fp
    That is the OSD (On Screen Display) system built-in to your computer monitor. Check that when you hit the ON/OFF button on your monitor, that you do *NOT* hit the 'OSD ON/OFF' button.
    Most of the time, the OSD will disappear after 10 seconds of "non-use".
    Dec 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
    Osd locked
    On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
    The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
    Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
    Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
    Note: These same buttons, when pressed for another 10 seconds, will lock the OSD.
    Nov 21, 2008 | ViewSonic E70f 17" CRT Monitor
    DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
    the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
    Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
    NEC 77F CRT monitor - displays alternating black \ white crosses
    Sounds like its stuck in test mode. Make sure that none of the buttons are stuck in place and does it make any noise while its turned on?
    Jul 19, 2007 | NEC MultiSync 77F 17 in.CRT Conventional...
    NEC 1740CX-BK (black) LCD Monitor Logo
    158 people viewed this question
    Top NEC Computers & Internet Experts
    Steven Wander
    Steven Wander
    Martin Murray
    Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
